Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI-TMS 122.3: Thermal Properties of Concrete and Masonry for Use in Determining Ener
12-15-2024, 06:51 AM
ACI-TMS CODE-122.3-24: Thermal Properties of Concrete and Masonry for Use in Determining Energy Code Compliance Except for Low-Rise Residential Buildings—Code Requirements and Commentary
| Size: 40.12 MB| Format: PDF| Quality: Scanner| Year: 2024| pages: 111 | ISBN: 9781641952545
[Image: 41730014554106085473.jpg]
This Code prescribes minimum design and construction requirements for energy efficiency of building envelopes of new buildings and additions to buildings. It applies to buildings having concrete walls, roofs, or floors; masonry walls; and masonry veneer, including veneer attached to frame walls as part of the building envelope. It also provides minimum thermal properties for these assemblies for code compliance.
This Code is applicable to commercial and mid- to high-rise residential buildings that use either electricity from any generation source or fossil fuel. It can be used with applicable energy codes and standards such as ASHRAE 90.1 and the International Energy Conservation Code (IECC).
energy efficiency; specific heat; thermal conductivity; thermal diffusivity; thermal resistance; thermal transmittance.
  • babakfeyzi, lisine
  ACI TMS 122.2: Thermal Properties of Concrete and Masonry for Use poolmand 0 1,472 05-26-2024, 04:51 AM
  [CivilEA Exclusive] ACI-TMS 122.1: Thermal Bridge Mitigation for Buildings Having Concrete and Masonry poolmand 0 1,414 10-21-2023, 11:59 AM
  ACI 216.1: Fire Resistance of Concrete & Masonry Construction Assemblies nibbi 2 2,534 05-08-2023, 08:44 AM
  ACI 207.2: Report on Thermal and Volume Change Effects on Cracking of Mass Concrete portal61 2 3,470 05-03-2023, 05:26 AM
