Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Evaluation of bolted CHS flange-plate connections under axial tension
[Request] Evaluation of bolted CHS flange-plate connections under axial tension
 civilfafa
Semi Senior Member
Iraq
User ID: 174183
Threads: 44
Likes: 304 in 50 posts
Given Likes: 459
06-29-2024, 03:35 AM
Hi There,
It is appreciated if someone could share the following paper:
Thanks.
Title of paper: Evaluation of bolted CHS flange-plate connections under axial tension
Journal: Journal of Constructional Steel Research
Authors: Augusto FidalgoJeffrey A. PackerORCID ID
Source Information Volume 196, September 2022, 107399
DOI URI :
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,708 in 1,305 posts
Given Likes: 4621
07-08-2024, 10:58 AM
[-] The following 4 users Like lisine's post:4 users Like lisine's post
  • civilfafa, babakfeyzi, tomtumx, zrilek
  [REQUEST] Bolted end-plate tube connections subject to tension and bending civilfafa 1 2,911 07-08-2024, 11:03 AM
  [REQUEST] Column Axial Load Effects on Performance of Panel Zone in Welded-Flange-Plate Connect ssobhan 1 1,688 10-17-2015, 08:49 PM
Last Post: Mohammad6299
