Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Bolted end-plate tube connections subject to tension and bending
[Request] Bolted end-plate tube connections subject to tension and bending
 civilfafa
Semi Senior Member
Iraq
User ID: 174183
Threads: 44
Likes: 304 in 50 posts
Given Likes: 459
06-29-2024, 03:32 AM
Hi There,
It is appreciated if someone could share the following paper:
Thanks.
Title of paper: Bolted end-plate tube connections subject to tension and bending
Journal: Canadian Journal of Civil Engineering / 51(1)
Authors: Augusto FidalgoJeffrey A. PackerORCID ID
Source Information September 2023, Volume51(Issue1)Pages, p.73To - 92 - Canadian Journal of Civil Engineering
DOI URI :
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
07-08-2024, 11:03 AM
Here is draft version
or a mirror in case you can not access previous links.
[-] The following 3 users Like lisine's post:3 users Like lisine's post
  • civilfafa, babakfeyzi, zrilek
  [REQUEST] Evaluation of bolted CHS flange-plate connections under axial tension civilfafa 1 2,946 07-08-2024, 10:58 AM
  [REQUEST] Approximate Analysis of Shear Walls Subject to Lateral Loads ssobhan 2 2,142 07-08-2015, 12:14 AM
Last Post: hessi
