Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA C602: Cement-Mortar Lining of Water Pipelines in Place—4 In. (100 mm) and Larger
01-15-2024, 10:34 AM
AWWA C602-23 Cement-Mortar Lining of Water Pipelines in Place—4 In. (100 mm) and Larger
| Size: 5.07 MB| Format: PDF| Quality: Scanner| Year: 2023 | ISBN: 9781647171278
[Image: 87359336729930283079.jpg]
The purpose of this standard is to define the minimum requirements for cement-mortar lining of water pipelines, 4 in. (100 mm) and larger, in place, including materials, design, and methods for construction.
This standard describes the requirements for the materials and application of a cement–mortar lining to the inside surface of 4-in. (100-mm) and larger new and old steel, ductile-iron, and cast-iron water pipelines that have been previously installed, as well as related work. The application requirements are that the lining of straight pipe sections and long-radius bends shall be performed by a machine that progresses uniformly through the pipe, applies cement mortar against the pipe surfaces, and is provided with an attachment for mechanically troweling the mortar to obtain a smooth lining of uniform thickness with smooth transitions over joints, and that the lining of bends, specials, and areas adjacent to valves shall be machine sprayed and hand troweled or, where machine placement is impractical, shall be performed manually. It can be referenced in documents for cement–mortar lining of water pipelines in place, 4 in. (100 mm) and larger.
  • PinkPant, babakfeyzi
  AWWA B304: Liquid Oxygen for Ozone Generation for Water, Wastewater, and Reclaimed W poolmand 0 2,813 01-16-2024, 08:10 AM
  AWWA B114: Reverse Osmosis and Nanofiltration Systems for Water Treatment poolmand 0 1,255 01-15-2024, 12:28 PM
  AWWA A100: Water Wells poolmand 0 1,491 01-15-2024, 11:44 AM
  AWWA D103 Factory-Coated Bolted Steel Tanks for Water Stor ir_71 2 4,172 09-04-2019, 08:45 AM
Last Post: pedzaquino
  AWWA M42: Steel Water-Storage Tanks Dell_Brett 3 3,066 07-02-2016, 05:22 AM
Last Post: mnovo
