Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS C4.4/C4.4M: Recommended Practices for Heat Shaping and Straightening with Oxyfuel
Likes: 8,200 in 1,338 posts
08-30-2023, 08:27 AM
AWS C4.4/C4.4M-2007: Recommended Practices for Heat Shaping and Straightening with Oxyfuel Gas Heating Torches
| Size: 787 KB| Format: PDF| Quality: Scanner| Year: 2nd Edition, 2007| pages: 53
AWS C4.4/C4.4M, 2nd Edition, 2007 - Recommended Practices for Heat Shaping and Straightening with Oxyfuel Gas Heating Torches
This publication describes some causes of distortion and corrective actions through the use of heat. It also describes some heat shaping techniques and the direction of movement expected in the heated metal. Equations are provided to aid in estimating the amount of movement for a given heating technique. The methods discussed are specifically applicable to ferrous metals, but many of the methods can be applied to nonferrous metals as well. For a more comprehensive description of specific applications, see the attached supplementary reading list.
Heat has been used to shape and straighten structural elements in bridges, buildings and marine constructions for over a hundred years. Since the late 1930s, the use of oxyfuel gas torches to do this work has become more and more prevalent. This publication is a recommended practice for using the torch process for work on bridges and buildings, and to some extent shipbuilding.
Mechanical forces in fabrication and erection, forces occurring in service, accidental impacts from external forces, fire, and explosion, all cause stress in a structural member or a part of a member. If that stress exceeds the elastic limit of the material, distortion will occur, and the member will not conform to its desired shape. Heat shaping and straightening is an economical method to produce the desired movement to bring the member into conformance.
The shipbuilding industry throughout the world has taken heat shaping to new heights in shaping technology. Particularly, the use of line heating to shape complex curves in hull structures has become an integral part of a group technology in shipbuilding which also includes product work packages and accuracy control.
Basically, straightening and shaping involves controlled thermal expansion and contraction of a structural element. The method, location, and shape of the heat application are covered briefly in this publication. This recommended practice is limited to fundamentals and simple applications. (See Annex A for additional information.)
  • PinkPant, babakfeyzi, kowheng
  AWS D14.7/D14.7M: Recommended Practices for Surfacing and Reconditioning of Industria poolmand 0 1,346 09-09-2023, 12:52 PM
  AWS D10.10/D10.10M: Recommended Practices for Local Heating of Welds in Piping and Tu poolmand 0 1,400 09-04-2023, 11:44 AM
  AWS D10.8: Recommended Practices for Welding of Chromium-Molybdenum Steel Piping and poolmand 0 1,635 09-04-2023, 11:40 AM
  AWS D10.6/D10.6M: Recommended Practices for Gas Tungsten Arc Welding of Titanium Pipe poolmand 0 1,315 09-04-2023, 11:35 AM
  AWS C7.2M: Recommended Practices for Laser Beam Welding, Cutting, and Allied Processe poolmand 0 1,389 09-02-2023, 09:39 AM
  AWS C7.1M/C7.1: Recommended Practices for Electron Beam Welding and Allied Processes poolmand 0 1,410 09-02-2023, 09:36 AM
  AWS C6.1: Recommended Practices for Friction Welding poolmand 0 1,294 09-02-2023, 09:20 AM
