Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering The dynamic stability of elastic systems - 1964
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
07-03-2018, 12:13 PM
Author(s)/Editor(s): Vladimir Vasilʹevich Bolotin | Size: 25 MB | Format: PDF | Quality: Scanner | Publisher: Holden-Day | Year: 1964 | pages: 451 | ISBN: 1114366099 / 978-1114366091
[Image: 33351634971202548691.jpg]
This book is an attempt to present systematically the general theory of dynamic stability of elastic systems and its numerous applications. Investigations of the author are used as the basis for the book, part of which was published previously in the form of separate articles. The author's method of presentation is retained where the problems treated have been analyzed by other authors.
The book is devoted to the solution of engineering problems. As in every other engineering (or physics) investigation, the presentation consists of first choosing an initial scheme or pattern, and then using the approximate mathematical methods to obtain readily understood results. This intent, and the desire to make the book easily understood by a large number of readers, is reflected in the arrangement and structure of the book. The book consists of three parts.
PART I is concerned with the simplest problems of dynamic stability which do not require complicated mathematical methods for their solutions. By using these problems, the author wishes to acquaint the reader with previously investigated problems. At the same time, certain peculiarities of the phenomena of instability, which previously have been only sketchily mentioned, are clarified. PART I also contains methods of solution of the general problem.
PART II begins with two chapters containing the minimum necessary mathematical information; a conversant reader can disregard these chapters. The properties of the general equations of dynamic stability are then examined; methods are presented for the determination of the boundaries of the regions of instability and the amplitudes of parametrically excited vibrations for the general case.
PART III is concerned with applications. Various problems of the dynamic instability of straight rods, arches, beams, statically indeterminate rod systems, plates, and shells are examined. The choice of examples was dictated by the desire to illustrate the general methods and present solutions to practical problems. The number of examples was limited by the size of the book.
[-] The following 16 users Like febo927's post:16 users Like febo927's post
  • civilfafa, jcbv, blaze, oanm2000, mgdario, gulilero, Ivan_1980, cace-01, Dell_Brett, PinkPant, hodzicemir, axcel, milova, zrilek, K.Lee, spat
 axcel
Bolivia
User ID: 11627
Threads: 16
Likes: 1,546 in 203 posts
Given Likes: 405
07-04-2018, 04:55 AM
[-] The following 7 users Like axcel's post:7 users Like axcel's post
  • PinkPant, cace-01, Dell_Brett, jcbv, oanm2000, zrilek, K.Lee
  FEMA 451B Topic 04 - Structural Dynamics of Linear Elastic MDOF Systems Dell_Brett 2 3,220 04-12-2019, 11:58 AM
  Vibrations and Stability of Complex Beam Systems cace-01 1 1,811 02-19-2015, 04:27 PM
Last Post: Veggeta
  Optimal Control Theory for the Damping of Vibrations of Simple Elastic Systems david-smith 2 2,206 03-23-2013, 02:20 PM
Last Post: arshiakh
  Dynamic Isolation Systems Set of Catalogues in seismic isolators david-smith 0 1,404 11-22-2012, 08:16 PM
Last Post: david-smith
  Ground-motion prediction equations, 1964–2010 pezhmankhan 1 2,266 05-10-2011, 08:38 PM
Last Post: ssobhan
