Civil Engineering Association eBooks Structural Books Steel Steel Design for the Civil PE and Structural SE Exams
 ibg0203
China
User ID: 1557
Threads: 280
Likes: 6,208 in 686 posts
Given Likes: 1411
07-15-2015, 03:24 PM (This post was last modified: 07-15-2015, 07:58 PM by usman.)
Steel Design for the Civil PE and Structural SE Exams, Second Edition
[Image: 07934121604525758432.jpeg]
  • Author(s): Frederick S. Roland PE SECB RA CFEI CFII
  • Published Year: 2014
  • Size: 4.4 MB
  • Quality: Unspecified
  • Abstract: An In-Depth Review of Steel Design Methods and Standards
    Steel Design for the Civil PE and Structural SE Exams gives you a thorough overview of the concepts and methods you’ll need to solve problems in steel analysis and design on the Civil and Structural PE exams. Sharpen your problem-solving skills and assess your knowledge of how to apply important specifications with 37 exam-like, multiple-choice practice problems, each one accompanied by a detailed, step-by-step solution showing both LRFD and ASD methods.
    Prepare to pass the Civil and Structural PE exams
    Clear explanations of required codes and standards
    Detailed examples illustrating a wide range of common situations
    Confidence-building practice problems
    Side-by-side LRFD and ASD solutions
    Thorough index and easy-to-use lists of tables, figures, problems, and nomenclature
    Topics Covered
    Allowable Strength Design (ASD)
    Bolted Connections
    Combined Stress Members
    Composite Steel Members
    Flanges and Weds with Concentrated Loads
    History and Development of Structural Steel
    Load and Resistance Factor Design (LRFD)
    Loads and Load Combinations
    Plate Girders
    Steel Beam Design
    Steel Column Design
    Tension Member Design
    Welded Connections
    Referenced Codes and Standards
    Steel Construction Manual and Specification (AISC 325 and AISC 360)
    Minimum Design Loads for Buildings and Other Structures (ASCE 7)
    International Building Code (IBC)
[-] The following 20 users Like ibg0203's post:20 users Like ibg0203's post
  • PinkPant, deviationz, Jackass, zrilek, RyanRS, shaker, inge911, malc, agarciam2, simanta, vvvv, carolinandra, emmi, cristi, xdesi, eng donny, SCREAM7890, bigone, K.Lee, zego2000
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
07-15-2015, 03:48 PM (This post was last modified: 07-15-2015, 04:08 PM by BennyP.)
[Image: 95216087703698175596.jpg]
[-] The following 12 users Like cace-01's post:12 users Like cace-01's post
  • PinkPant, SCREAM7890, deviationz, zrilek, Dell_Brett, m_zaman94, malee, oanm2000, rezart, eng donny, RyanRS, bigone
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
07-19-2015, 11:50 PM
[-] The following 15 users Like gulilero's post:15 users Like gulilero's post
  • viet2010, Dell_Brett, milova, Trishu999, PinkPant, rezart, blaze, KhaLed-S.E, highcivil, oanm2000, ruaumoko, Andrew seah, eng donny, bigone, jik686
 KhaLed-S.E
Egypt
User ID: 48176
Threads: 43
Likes: 1,063 in 98 posts
Given Likes: 490
07-20-2015, 01:48 PM
Steel Design for the Civil PE and Structural SE Exams, 2nd Ed,2014
[-] The following 12 users Like KhaLed-S.E's post:12 users Like KhaLed-S.E's post
  • oanm2000, PinkPant, melekeen, mgdario, blaze, dinu69in, eng donny, civilgen, bigone, Dell_Brett, usman, ting tsai huang
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
11-09-2015, 06:35 PM
[-] The following 16 users Like bigone's post:16 users Like bigone's post
  • nickycruz, Dell_Brett, K.Lee, agelos100, Andrew seah, psk62, rendel_©, malc, simanta, dizz, blaze, PinkPant, bridgeengineer, avge, engrezi, zego2000
 bigone
User ID: 4505
Threads: 92
Given Likes: 7145
11-09-2015, 06:41 PM
Steel Design for the Civil PE and Structural SE Exams, 1st Ed
Author(s)/Editor(s): Frederick S. Roland PE | Size: 9.6 MB | Format: PDF | Quality: Scanner | Publisher: Professional Publications, Inc. | Year: 2012 | pages: 612 | ISBN: ISBN-10: 1591263794 ISBN-13: 9781591263791
[Image: 45661293925704100422.jpg]
Steel Design for the Civil PE and Structural SE Exams provides a comprehensive overview of the key elements of structural steel design and analysis. It presents and illustrates the application of the most relevant concepts and equations from the codes and design standards adopted for use in the national Civil PE and Structural SE licensing exams.
Critical Feature:  Side by side LRFD and ASD solutions show where the two methods are the same and where they differ. This means you won’t have to study two different solution methods and spend extra time trying to determine where they differ.
Prepare to Pass Any Steel Question on Your Exam
More than 50 examples and 35 practice problems
Detailed solutions reference the applicable standards and specific Steel Manual sections, equations, or table numbers
A thorough index and easy-to-use lists of tables, figures, and nomenclature
Nomenclature and terminology matches the Steel Manual
Exam Topics Covered
Bolted Connections
Design and Analysis Methods
Flanges and Webs
Plate Girders
Practice Problems
Steel Beam Design
Steel Column Design
Structural Steel
Welded Connections
Moderator Note:
- Correct ISBN Number (removed dashes)
[-] The following 15 users Like bigone's post:15 users Like bigone's post
  • agelos100, sabooryan, Dell_Brett, nickycruz, amindoxiti, usman, ting tsai huang, Jackass, cace-01, malc, bridgeengineer, f_slikken, mgdario, oanm2000, slowet
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2618
11-09-2015, 08:17 PM (This post was last modified: 11-09-2015, 08:22 PM by amindoxiti.)
The first 209 pages have been scaned twice.In fact, the book has 403 pages.
[-] The following 10 users Like amindoxiti's post:10 users Like amindoxiti's post
  • bigone, usman, Dell_Brett, cace-01, malc, knrsa, PinkPant, oanm2000, monter, zego2000
  Benchmark cases for advanced design of structural steel connection melekeen 1 3,756 06-22-2024, 04:05 AM
  Australia Steel Institute - Design capacity tables for structural steel leong8929 5 6,362 12-26-2022, 10:41 AM
  Structural Steel Design: A Practice Oriented Approach -- Aghayere, Vigil psa_1987 10 9,762 02-11-2021, 02:20 AM
Last Post: eng donny
  Structural Steel Design: Jack C. McCormac saqib 20 20,933 11-16-2020, 02:28 PM
Last Post: KMABD
  Structural Depth Practice Exams for the Civil PE Exam, Second Edition ibg0203 1 2,220 02-08-2020, 01:53 AM
  Structural Steel Drafting and Design adshrt 3 3,585 07-20-2018, 12:58 PM
Last Post: febo927
  Applied Structural Steel Design - by Leonard Spiegel usman 3 4,984 06-14-2018, 12:26 PM
Last Post: febo927
