Civil Engineering Association eBooks Structural Books Steel Structural Depth Practice Exams for the Civil PE Exam, Second Edition
 ibg0203
China
User ID: 1557
Threads: 280
Likes: 6,208 in 686 posts
Given Likes: 1411
11-11-2015, 02:35 AM
Author(s)/Editor(s): James Giancaspro PhD PE | Size: 3 MB | Format: PDF | Quality: Scanner | Publisher: Professional Publications, Inc. | Year: 2014 | pages: 96 | ISBN: 1591264618
[Image: 54474818878549848432.jpeg]
Two Realistic, 40-Problem Structural Depth Exams
Structural Depth Practice Exams for the Civil PE Exam contains two 40-problem, multiple-choice exams consistent with the NCEES Civil PE structural depth exam’s format and specifications.
Consistent with the actual exam, the problems in Structural Depth Practice Exams for the Civil PE Exam require an average of six minutes to solve. Enhance your time-management skills by taking each exam within the same four-hour time limit as the actual exam. Then, evaluate your performance using the two individual answer keys. Comprehensive step-by-step solutions demonstrate accurate and efficient problem-solving approaches. Solutions also frequently refer to the codes and references adopted by NCEES to help you determine which resources you’ll likely use on exam day.
Structural Depth Practice Exams will help you to:
effectively familiarize yourself with the exam scope and format quickly identify accurate and efficient problem-solving approaches successfully connect relevant theory to exam-like problems efficiently navigate through exam-adopted codes and standards confidently solve problems under timed conditions
Referenced Codes and Standards
AASHTO LRFD Bridge Design Specifications (AASHTO)
Building Code Requirements for Structural Concrete (ACI 318)
Building Code Requirements for Masonry Structures (ACI 530)
Minimum Design Loads for Buildings and Other Structures (ASCE7)
Structural Welding Code—Steel (AWS D1.1)
International Building Code (IBC)
National Design Specification for Wood Construction ASD/LFRD (NDS)
PCI Design Handbook (PCI)
Steel Construction Manual (AISC)
[-] The following 31 users Like ibg0203's post:31 users Like ibg0203's post
  • gulilero, K.Lee, cace-01, Andrew seah, malc, zrilek, dizz, blaze, knrsa, Dell_Brett, ska51, simanta, f_slikken, oanm2000, PinkPant, bigone, eng donny, Jackass, psk62, subin91, lisine, bridgeengineer, ruaumoko, araza023, cristi, monter, Trishu999, xdesi, zego2000, usman, davegabj
02-08-2020, 01:53 AM
[-] The following 10 users Like kowheng's post:10 users Like kowheng's post
  • onest30, milova, 88FeNIX, Dell_Brett, Nita1391, PinkPant, pedzaquino, Wijono, rami1976, oanm2000
  Steel Design for the Civil PE and Structural SE Exams ibg0203 6 3,945 11-09-2015, 08:17 PM
  Structural Steel Erection Best Practice jamildear4u 0 1,595 01-25-2012, 05:18 PM
Last Post: jamildear4u
