Civil Engineering Association eBooks Structural Books Steel Australia Steel Institute - Design capacity tables for structural steel
 leong8929
User ID: 786
Threads: 34
Likes: 385 in 18 posts
Given Likes: 7
08-23-2012, 01:28 PM (This post was last modified: 08-23-2012, 01:54 PM by leong8929.)
Design capacity tables for structural steel, vol. 1: Open sections
Author: Australian Steel Institute | Size: 12 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 2009-10-07 | pages: 286 | ISBN: 9781921476204
[Image: 13172792843183403956.jpg]
This design aid to the limit states standard AS 4100-1998 considers open type hot-rolled sections and standard open sections manufactured from hot-rolled plate. Data includes among others: dimensions and section properties, design section capacities, values for fire design, design capacities for members subject to bending, shear , bearing, axial compression, axial tension and combined actions. This new edition was published in October 2009 and updates the third edition of 1999.
The second printing of this edition includes the technical revision of September 2010 to Part 13 Crane runway beams and monorail beams.
Design capacity tables for structural steel, vol. 2: Hollow sections
Author: Australian Steel Institute | Size: 12 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 1999-01-01 | pages: 320 | ISBN: 0909945934
[Image: 55633503843925060726.jpg]
Design capacity tables for structural steel hollow section
Design capacity tables for structural steel, vol. 3: Simple connections - Open sections
Author: Hogan, T.J. and Munter, S.A. | Size: 2 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 2007-12-01 | pages: 75 | ISBN: 9780980401585
[Image: 08828903604173243504.jpg]
This consolidates all the design capacity tables contained in the individual simple connection design guides into one volume for easy reference and comparison. These tables aim to replace the simple connections section of AISC Standardised Structural Connections (3rd edition, 1985) and also provide typical details for web side plate, flexible end plate and angle cleat connections.
The capacity tables have been developed for selected connection configurations covering: steel grade, connection components such as plates or cleats, welds, bolts, hole geometry, bolt pitches and bolt gauges.
For a selected connection configuration, most design calculations are eliminated using the tables except for design checks which relate to the supporting member or general frame design. Information on the design model used for each connection can be found in the relevant design guide for that connection.
[-] The following 29 users Like leong8929's post:29 users Like leong8929's post
  • blaze, dovsky, avscorreia, malc, david-smith, miquan, ikoleci, Hengki, jcoronellr, duazo2009, tomtumx, adams, pingfan2, subin91, Jackass, shadabg, cace-01, knrsa, eng donny, cristi, l_namali, monter, ranui30, suseeraj, zrilek, brandanc, amindoxiti, oanm2000, kowheng
08-24-2012, 06:41 AM
vol. 1 :
vol. 2 :
vol. 3 :
[-] The following 13 users Like shadabg's post:13 users Like shadabg's post
  • abhijit, melekeen, Dell_Brett, dinu69in, slowet, eng donny, durden, ting tsai huang, Matt89, jamalsbaih, blaze, zrilek, Albert
 rami1976
User ID: 34597
Threads: 341
Likes: 9,523 in 1,137 posts
Given Likes: 1387
02-08-2019, 07:43 PM
Design Capacity Tables for Structural Steel Hollow Sections
[-] The following 7 users Like rami1976's post:7 users Like rami1976's post
  • Dell_Brett, Andrew seah, hatkam, vvvv, sodapas, PinkPant, oanm2000
 agelos100
Member
User ID: 34967
Threads: 15
Likes: 173 in 18 posts
Given Likes: 378
03-26-2020, 08:54 AM
  • Size: 2.7 MB
  • Quality: Original Preprint
[-] The following 10 users Like agelos100's post:10 users Like agelos100's post
  • Dell_Brett, cheosmith, Aviator, jcbv, oanm2000, babakfeyzi, mgdario, kowheng, PinkPant, malc
Away  bridgeengineer
Semi Senior Member
Banned
Poland
User ID: 93214
Threads: 49
Likes: 1,023 in 110 posts
Given Likes: 4769
12-25-2022, 04:25 PM
please reupload Design capacity tables for structural steel 3 parts
thanks
12-26-2022, 10:41 AM
[-] The following 8 users Like poolmand's post:8 users Like poolmand's post
  • bridgeengineer, zrilek, Dell_Brett, mgdario, PinkPant, rami1976, cace-01, milova
  Benchmark cases for advanced design of structural steel connection melekeen 1 3,717 06-22-2024, 04:05 AM
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 3,008 01-10-2023, 12:16 AM
Last Post: carolinandra
  Steel Plate Shear Walls with Gravity Load: Theory and Design carolinandra 2 3,376 12-26-2022, 10:45 AM
  Cold-Formed Steel Design Flexi 21 17,786 09-03-2022, 04:21 AM
  Steel Structures Design; For Lateral and Vertical Forces carolinandra 3 4,146 01-07-2022, 02:44 AM
Last Post: Veggeta
  Design of steel bins for storage of bulk solids zrilek 2 3,246 01-04-2022, 06:19 PM
Last Post: usman
  Steel Building Design: Concise Eurocodes jamildear4u 3 4,744 12-02-2021, 02:23 PM
Last Post: babakfeyzi
