Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8539:2012 Code of practice for the selection and installation of post-installed an
03-17-2015, 05:51 AM
BS 8539:2012 Code of practice for the selection and installation of post-installed anchors in concrete and masonry
Author: Technical Committee B/514 | Size: 3.54 MB | Format: PDF | Quality: Original preprint | Publisher: BSI | Year: 2012 | pages: 80 | ISBN: 9780580703294
[Image: 81125178095479183791.jpg]
This British Standard gives recommendations for the safe selection and installation of anchors for use in concrete and masonry. It is intended to provide practical guidance for designers, specifiers, manufacturers, suppliers, contractors, installers and testers of anchors.
In particular, this British Standard applies to the selection and installation of anchors which are used in safety-critical applications.
This British Standard is restricted to the use of anchors which are inserted into concrete and masonry in drilled holes.
  • concreteok, PinkPant, zrilek, blaze, Dell_Brett, f_slikken, Jackass, bridgeengineer, vvvv, junaid, oanm2000, malc, peixoto, slowet
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 402
03-17-2015, 03:05 PM
[-] The following 4 users Like Veggeta's post:4 users Like Veggeta's post
  • vvvv, PinkPant, oanm2000, uetian19
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,218 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,528 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,083 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,079 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,310 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,688 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,264 02-17-2021, 11:20 AM
Last Post: temp1366
