Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8476: Code of practice for the safe use of concrete pumps
11-10-2010, 07:16 AM (This post was last modified: 02-14-2022, 05:43 AM by Administrator.)
BS 8476:2007 Code of practice for the safe use of concrete pumps
BS 8476:2997 gives recommendations for the safe use of concrete pumping and placing equipment. It is not applicable to plaster and screed pumps, nor applicable to the construction of the machinery, which is covered by BS EN 12001.
Contents
Foreword
1 Scope
2 Terms and definitions
3 Selection of personnel
4 Training and certification
5 Management of the concrete pumping operation
6 Selection of concrete pumps
7 Travelling to and from the site
8 Arrival on site and setting up the machine
9 During the pour
10 Work with delivery lines
11 Pumping special concretes
12 Cleaning out the machine and delivery lines
13 Leaving the site (lorry-mounted concrete pumps)
14 Personal protective equipment
15 Concrete pump examination and testing
16 Maintenance
Annexes
Annex A (normative) Recommended signals
Annex B (normative) Inspection of delivery lines
Annex C (informative) Pipeline wall thickness pressure – Maintenance card
Bibliography
:JC_cheers:
  • kowheng, Dell_Brett, hmwere, zrilek, roaming79, toa011, Grunf, parwez007, Adam Smith, oanm2000, ziadjordan, sivlad, peixoto
10-10-2012, 04:52 AM
New links:
[-] The following 4 users Like ir_71's post:4 users Like ir_71's post
  • Dell_Brett, peixoto, Jackass, zrilek
02-12-2022, 08:00 AM
  • Administrator , Dell_Brett, CAMSECT, oanm2000, PinkPant
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,297 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,568 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,166 06-07-2023, 05:10 AM
Last Post: ersin
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,345 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,706 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,288 02-17-2021, 11:20 AM
Last Post: temp1366
  BS 7255:2001 Code of practice for Safe working on lifts ir_71 2 2,782 08-09-2019, 10:11 PM
Last Post: Nita1391
