Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Behavior and Vulnerability of Reinforced Masonry Shear Walls
11-02-2013, 10:54 AM
Author: Ehsan Minaie in partial fulfillment of the requirements for the degree of Doctor of Philosophy | Size: 18.6 MB | Format: PDF | Quality: Unspecified | Publisher: Drexel University | Year: august 2009 | pages: 488
[Image: 09850655937754506908.png]
The overarching goal of the research presented herein was to establish the key behavior mechanisms and seismic vulnerabilities of reinforced masonry (RM) shear walls. Currently, there are knowledge gaps related to partially grouted masonry shear walls, regarding their failure mechanisms, applicability of current code provisions to PG walls, and influence of bidirectional loading on the behavior of such walls. To bridge these gaps a research program that integrated both experimental and analytical approaches was conducted. The centerpiece of the experimental program was a series of full-scale, quasi- static cyclic tests of both PG and FG masonry shear walls. Key test parameters included the level of vertical stress, wall aspect ratio, and mortar formulation. Following these experiments a series of nonlinear finite element models were developed and correlated with the experimental results. These models were then used to examine the influence ofbi-directional loading through a series of parametric studies with out-of-plane drift, wall aspect ratio and vertical stress as variables. Results of this study indicated a potentially significant seismic vulnerability of PG masonry shear walls that is not reflected in current design provisions. The PG masonry shear walls tested displayed shear strengths less than half of the capacity estimated by current design methods. The modeling component of this research developed an efficient nonlinear finite element modeling approach that proved capable of simulating the capacity (within 10%), failure modes and hysteretic response of both PG and FG masonry shear walls. This modeling approach was also validated for the prediction of out-of-plane response, and then used to examine the bi- directional response of PG masonry shear walls. Results from this study indicated that out-of-plane drifts corresponding to the collapse prevention limit state may reduce the in- plane capacity of PG walls by more than 20%. Although the capacity of PG walls is influenced by out-of-plane drifts, their hysteretic responses, and in particular, energydissipation and ductility capacities remain nearly unchanged. As a result, the seismic response of PG masonry walls is likely only nominally affected by bi-directional ground motions.
  • blaze, rezart, malc, Dell_Brett, vardan
  Mechanical behavior of RC walls under seismic activity strenghtened with CFRP TAFATNEB 1 1,868 02-09-2015, 04:42 PM
Last Post: Veggeta
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 1,821 10-08-2014, 02:00 PM
  A Study of the Progressive Degradation of Masonry Shear Walls Subjected to Harmonic L TAFATNEB 0 1,642 06-04-2014, 12:00 AM
  SHEAR STREN GTH OF CIRCULAR REINFORCED CONCRETE COLUMNS TAFATNEB 0 1,621 06-01-2014, 03:41 PM
  PUNCHING SHEAR STRENGTH AND DE FORMATION CAPACITY OF FIBER REINFORCED CONCRETE SLAB-C TAFATNEB 0 1,637 06-01-2014, 03:30 PM
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,671 05-30-2014, 02:05 PM
  Seismic Performance, Modeling, and Failure Assessment of Reinforced Concrete Shear Wa TAFATNEB 0 1,680 05-09-2014, 04:00 PM
