Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis DRIFT CAPACITY OF REINFORCED CONCRETE COLUMNS SUBJECTED TO DISPLACEMENT REVERSALS
10-04-2013, 07:04 PM
Author: Santiago Pujol | Size: 0.4 MB | Format: PDF | Quality: Unspecified | Year: August 2002 | pages: 77
In previous tests of columns under displacement reversals in the inelastic range of response, different arbitrary displacement histories have been used. Comparisons of drift-capacity data from columns tested under different displacement histories can only be made if displacement-history effects are ignored. Possibly because of this reason, currently available methods for column drift capacity ignore displacement-history effects. To investigate whether drift capacity is a function of displacement history, sixteen cantilever columns were tested under various displacement patterns. The test results indicate that column drift capacity is sensitive to displacement history. For columns cycled beyond yield, drift capacity decreases as a function of the amplitude and number of cycles the column has experienced. Based on measurements of average unit strains in the transverse reinforcement, a model is proposed for estimating the drift capacity for a given column under any symmetric displacement pattern.
  • vardan, rezart, malc, parthiban, cace-01, blaze, Dell_Brett, sodapas
  Reliability of Steel Columns Protected by Intumescent Coatings Subjected to Fire Dell_Brett 0 3,021 05-08-2017, 08:52 AM
Last Post: Dell_Brett
  SHEAR STREN GTH OF CIRCULAR REINFORCED CONCRETE COLUMNS TAFATNEB 0 1,617 06-01-2014, 03:41 PM
  PUNCHING SHEAR STRENGTH AND DE FORMATION CAPACITY OF FIBER REINFORCED CONCRETE SLAB-C TAFATNEB 0 1,634 06-01-2014, 03:30 PM
  EFFICIENT FINITE ELEMENT MODELING OF REINFORCED CONCRETE COLUMNS CONFINED WITH FIBER TAFATNEB 0 1,651 03-31-2014, 10:33 PM
  Dynamic Behaviour of Concrete Structures subjected to Blast and Fragment Impacts TAFATNEB 0 1,703 08-31-2013, 05:03 PM
  DETERMINING STRENGTH CAPACITY OF DETERIORATED REINFORCED CONCRETE BRIDGE SUBSTRUCTURE TAFATNEB 0 1,490 08-25-2013, 01:14 PM
  Full-Scale Experimental & Analytical Studies on High Strength Concrete Columns asim99 0 1,651 01-15-2013, 10:07 PM
Last Post: asim99
