Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 5395-2-1984 Stairs, ladders & walkways. Code of practice for the design of helical
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
02-21-2013, 01:20 PM (This post was last modified: 02-21-2013, 01:25 PM by andersen3.)
BS 5395-2-1984 Stairs, ladders and walkways. Code of practice for the design of helical and spiral stairs
Size: 195 KB | Format: PDF | Quality: Original preprint | Year: 1984 | pages: 18
[Image: 16313866291625345905.jpg]
BS 5395-2 gives recommendations for the design of helical and spiral stairs, to be used internally or externally in all types of building constructions.
It covers only stairs which are circular on plan and does not deal with ramps.
BS 5395-2 also gives guidance on the geometry of helical and spiral stairs.
Contents of BS 5395-2:
• Foreword
• Scope
• Definitions
• Alternative materials, components and methods of design and construction
• Materials
• Design
• Fire protection and means of escape
• Load tests
• Design geometry
• Typical layouts for stairs
• Relationship between rise and going
• Measurement of clear width and goings
• Landings
• Maximum gap between column and tread
• Calculation of going
• Calculation of clear headroom
• Structural materials
• Sizes of stairs
• Publications referred to
[-] The following 15 users Like andersen3's post:15 users Like andersen3's post
  • Quantumm, jcbv, gulilero, kowheng, malc, slowet, Dell_Brett, peixoto, mahyarov, asim99, chenamoy, Trishu999, zrilek, blaze, lisine
 andersen3
User ID: 464
Threads: 54
Given Likes: 1243
07-17-2014, 07:21 AM
password
[-] The following 7 users Like andersen3's post:7 users Like andersen3's post
  • zrilek, vvvv, Mohammad6299, Andrew seah, vardan, milova, Dell_Brett
 andersen3
User ID: 464
Threads: 54
Given Likes: 1243
03-05-2015, 03:32 PM
password:
  • eliseo.as, GMianG, PinkPant, bridgeengineer, cristi, Dell_Brett
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,371 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,593 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,237 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,127 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,379 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,745 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,313 02-17-2021, 11:20 AM
Last Post: temp1366
