Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Design of Inclined Loaded Drilled Shafts in High-Plasticity Clay Environment
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 07:38 PM
Author: Puppala, Anand J | Size: 7.23 MB | Format: PDF | Quality: Original preprint | Publisher: University of Texas, Arlington | Year: 2011 | pages: 242
[Image: 08700962579177608598.png]
Drilled shaft foundations are principally used to support many structures such as bridge piers, towers, buildings, transmission towers, and roadway cable barriers. This research focuses on the use of drilled shafts in the cable median barrier systems which play an important role in protecting people’s lives due to cross-over collisions on highways. During December 2006 to February 2007, several failures of 3-cable median barrier (TL-3) were observed in Kaufman County near Dallas without any traffic-related vehicular impacts. Preliminary investigation of failures showed that failed drilled shafts were located in high plasticity clay. Causes of failures are attributed to cold temperature induced shrinkage in the cables that increased in the tension in them, soil saturation due to long periods of rainfall and small sizes of drilled shafts used. Various sizes of drilled shafts were established and constructed in an environment similar to the one in which foundation distress was observed. Geotechnical sampling and laboratory testing were performed, and a new test setup for the application of an inclined tensile loading on drilled shafts was designed to simulate the loading under real field conditions. The capacities of different sizes of drilled shafts from field test were tested and measured under this setup. Once good simulation was obtained, the models are used for various foundation dimensions and various undrained shear strengths of soils which, in turn, provided results that are used in the development of foundation design charts. Additionally, construction guidelines and recommendation for periodic maintenance are provided in this report.
  • cace-01, Evandrojr, kowheng, malc
  Group Efficiencies of Grout-Tipped Drilled Shafts and Jet-Grouted Piles mahyarov 0 1,606 10-27-2012, 07:54 PM
Last Post: mahyarov
  Modeling of Laterally Loaded Drilled Shafts Behind Mechanically Stabilized Earth Bloc mahyarov 0 1,533 10-27-2012, 07:44 PM
Last Post: mahyarov
  Drilled Shaft Bridge Foundation Design Parameters and Procedures for Bearing in SGC S mahyarov 0 1,497 10-27-2012, 07:41 PM
Last Post: mahyarov
  Modeling of Pile Footings and Drilled Shafts for Seismic Design mahyarov 0 1,600 10-27-2012, 06:28 PM
Last Post: mahyarov
