Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Modeling of Laterally Loaded Drilled Shafts Behind Mechanically Stabilized Earth Bloc
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 07:44 PM
Modeling of Laterally Loaded Drilled Shafts Behind Mechanically Stabilized Earth Block Walls
Author: Pierson, Matthew | Size: 4.49 MB | Format: PDF | Quality: Original preprint | Publisher: University of Kansas, Lawrence | Year: 2011 | pages: 164
[Image: 25828062853952313282.png]
Mechanically stabilized earth (MSE) walls are recognized as a cost effective earth retention technology. In some cases structural foundations must pass through the reinforced fill due to the required footprint of the reinforced zone behind the facing. Limited information about the interaction between the structure and the MSE mass has been published, making efficient design difficult. It would be prohibitively expensive to construct and test all possible geometries or applications; therefore numerical modeling must be used to supplement physical data. This report contains a discussion of the analysis of physical test data and numerical modeling of an MSE test wall containing foundation elements. The test wall consists of an MSE wall with cast-in-place shafts contained within and solely supported by the reinforced fill. The finite difference numerical modeling program FLAC3D was used for analysis. A parametric study was conducted to determine how the various constituents of the physical wall as well as wall height affect wall-shaft behavior. Geogrid properties, particularly stiffness, were found to have the greatest influence on behavior. Wall height has a large influence on capacity at shaft movement of more than 2 inches. Analyses of the modeling results were used to create design recommendations for MSE walls with foundation elements.
[-] The following 1 user Likes mahyarov's post:1 user Likes mahyarov's post
  • Evandrojr
  Group Efficiencies of Grout-Tipped Drilled Shafts and Jet-Grouted Piles mahyarov 0 1,606 10-27-2012, 07:54 PM
Last Post: mahyarov
  Design of Inclined Loaded Drilled Shafts in High-Plasticity Clay Environment mahyarov 0 1,589 10-27-2012, 07:38 PM
Last Post: mahyarov
  Modeling of Pile Footings and Drilled Shafts for Seismic Design mahyarov 0 1,601 10-27-2012, 06:28 PM
Last Post: mahyarov
