Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Drilled Shaft Bridge Foundation Design Parameters and Procedures for Bearing in SGC S
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 07:41 PM
Drilled Shaft Bridge Foundation Design Parameters and Procedures for Bearing in SGC Soils
Author: Houston, William N Arizona State University, Tempe Harraz, Abdalla M Walsh, Kenneth D Houston, Sandra L Arizona State University, Tempe Perry, Courtland | Size: 2.11 MB | Format: PDF | Quality: Original preprint | Publisher: Arizona State University, Tempe | Year: 2011 | pages: 126
[Image: 38630288508845223728.png]
This report provides a simplified method to be used for evaluating the skin friction and tip resistance of axially loaded drilled shafts. A summary of literature and current practice was completed and then a comprehensive set of field and laboratory tests was performed. Several soil samples were collected from different sites from Arizona and surrounding states. Large scale direct shear apparatus was developed and used to determine the friction between soil and concrete. Finite element analyses were conducted on several prototype cases to determine effect of soil parameters such as dilation on the skin friction values. A step-by-step simplified approach was introduced to determine the skin and tip resistance of drilled shaft foundations in gravelly soils. An example application was presented to guide users in utilizing the simplified approach.
  • cace-01, Evandrojr, kowheng, malc, isurya
  Design of Inclined Loaded Drilled Shafts in High-Plasticity Clay Environment mahyarov 0 1,593 10-27-2012, 07:38 PM
Last Post: mahyarov
  Modeling of Pile Footings and Drilled Shafts for Seismic Design mahyarov 0 1,601 10-27-2012, 06:28 PM
Last Post: mahyarov
  Evaluation of Geotechnical Design Parameters Using the Seismic Piezocone isurya 3 3,350 08-23-2012, 08:44 AM
Last Post: shadabg
