Civil Engineering Association eBooks Structural Books Concrete Design Guidelines for Durability of Bonded CFRP Repair/Strengthening of Concrete Beam
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-25-2012, 02:44 PM
Design Guidelines for Durability of Bonded CFRP Repair/Strengthening of Concrete Beams
Author: Dowling, Richard | Size: 0.98 MB | Format: PDF | Quality: Original preprint | Publisher: Transportation Research Board | Year: 2008 | pages: 63 | ISBN: -
[Image: 47175276097953723129.png]
This research provides a methodology for evaluation of durability related strength loss of bonded carbon fiber reinforced polymer (CFRP) systems applied to concrete beams. The report addresses test methods to establish a durability strength reduction factor, identification of corresponding field exposure conditions affecting durability, and suggestions for the application of the durability strength reduction factor for design of field applications. The durability strength reduction factor is a measure of the loss in strength over time due to environmental exposure. It is defined as the ratio of the flexural strength of a 4 in. x 4 in. x 14 in. concrete beam reinforced with CFRP exposed at 140°F and submerged in water or 100% relative humidity for 60 days to the flexural strength of a control specimen. The resulting durability strength reduction factor may be used to evaluate CFRP system performance. Two field environments are suggested: Wet and Air. In a Wet environment water accumulates at the bond surface. This is the default condition and corresponds to test results in submerged water at 140°F for 60 days. An Air environment allows drying between wetting episodes so water cannot accumulate on the bond surface. This condition corresponds to test results in 100% relative humidity at 140°F for 60 days.
  • kowheng, lisine, cace-01, Dell_Brett, blaze, GMianG
  CS TR?: Assessment, Design and Repair of Fire-Damaged Concrete Stuctures ir_71 6 12,713 08-27-2025, 03:39 AM
Last Post: concreteok
  Strengthening of Concrete Structures carolinandra 0 2,949 02-09-2023, 02:09 PM
Last Post: carolinandra
  Guidelines for the Simplified Design of Structural Reinforced Concrete for Buildings killoobilloo 3 6,124 12-28-2022, 09:55 PM
  Corrosion of Steel In Concrete: Understanding, investigation and repair Grunf 12 8,074 12-25-2022, 10:10 PM
  CS TR 69 - Repair of concrete structures with reference to BS EN 1504 ir_71 2 3,120 02-06-2022, 12:32 PM
Last Post: babakfeyzi
  Concrete Repair: A Practical Guide cace-01 6 5,031 02-06-2022, 11:44 AM
  Design procedures for the use of composites in strengthening of reinforced concrete s xnr09 3 2,641 02-06-2022, 08:27 AM
