Civil Engineering Association eBooks Structural Books Concrete CS TR?: Assessment, Design and Repair of Fire-Damaged Concrete Stuctures
07-09-2011, 04:11 AM (This post was last modified: 12-14-2011, 11:14 PM by usman.)
Concrete Society - Assessment, design and repair of fire-damaged concrete structures
(Final Draft)
Size: 0.86 MB | Format: PDF | Publisher: Concrete Society | Year: 2008 | pages: 83
[Image: 55139136684596216499.jpg]
The emphasis of this report is on methods for assessing a concrete structure following a fire and hence for determining the extent of the required repairs. The design approaches used to assess the strength of repaired elements, illustrated by the design examples in Appendix B, are in accordance with the relevant Eurocodes(3, 4, 5). In addition to structural damage, there may be smoke damage to partitions, electrical and mechanical systems etc. Although the associated costs of cleaning or replacing such systems can be significant, they are not considered in this report. The focus of this report is on fires in reinforced concrete buildings, including multi-storey structures, warehouses and factories, but the principles are equally applicable to civil engineering structures, such as bridges. However, tunnels are specifically excluded as an assessment of their performance will require specialised geotechnical input, which is beyond the scope of this report. There is a major difference between designing a structure to withstand a fire, allowing for safe evacuation and fire fighting, and assessing the extent of damage caused by a fire so that repair methodologies can be proposed. While designing structures is predicting performance during a future event, assessing structures is determining its residual strength after such an event. Hence, the focus in the latter case and in this report is on methodologies to measure on site the residual strength and deformations and to obtain evidence of the temperatures reached during the fire. Calculation methodologies are presented that may assist during the evaluation process, but the working party felt that any assessment needs to be based mainly on an on-site evaluation of the fire damaged structure, which is supplemented as necessary by laboratory testing, examination or numerical assessment. In all cases, it is important that the assessment work is carried out by a competent person, who is aware of the limits of applicability for any methodology and whether special considerations for certain construction methods are required. The competent person needs to be aware that material properties and calculation methodologies presented in Eurocode 2 may not be applicable to the specific situation, since effects such as cooling of the structure or restraint and residual stresses need consideration after a fire event. This means that although the structure may have served its purpose according to Building Regulations and allowed for safe evacuation and fire fighting, considerable effort may be required to strengthen the structure for future occupation after a fire. A brief chapter on repair techniques is included, which makes reference to more detailed guidance. The working party considered that techniques are common to all repairs, irrespective of the cause of the damage, and not simply to the repair of fire-damaged concrete structures. Finally appendices to the report includes summaries of a number of case studies of the assessment and repair of structures damaged by fire, worked examples and historical information on design and material properties given in British Standards and other documents.
[-] The following 20 users Like ir_71's post:20 users Like ir_71's post
  • Jackass, vvvv, zrilek, nigema, malc, tluc, ladjin, Trishu999, cristi, ting tsai huang, Nilupa, salahcivil, GMianG, Dell_Brett, ssobhan, oanm2000, nhim4mat2006, asim99, bigone, K.Lee
12-24-2012, 07:58 AM
New links:
  • ykhackhack, malc, Dell_Brett, ssobhan, ting tsai huang, oanm2000, nhim4mat2006, asim99, bigone, blaze
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
08-02-2013, 06:18 AM
see here:
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  • Dell_Brett, bigone
06-25-2014, 04:05 AM
  • jcbv, Mohammad6299, malc, cace-01, Trishu999, blaze, Dell_Brett, Andrew seah, knrsa, mgdario, aslam, miquan, pram, bigone
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
04-18-2017, 03:51 AM
MIRROR:
[-] The following 18 users Like aslam's post:18 users Like aslam's post
  • faros3000, K.Lee, milova, blaze, zrilek, ck1999ck, er.shyams, oanm2000, Nita1391, cristi, Andrew seah, Aviator, Dell_Brett, gulilero, Wijono, chenamoy, Trishu999, techno
 babakfeyzi
Semi Senior Member
Romania
User ID: 177117
Threads: 15
Likes: 626 in 97 posts
Given Likes: 1379
02-11-2022, 08:40 PM (This post was last modified: 02-14-2022, 09:39 PM by oanm2000.)
Hi
[-] The following 5 users Like babakfeyzi's post:5 users Like babakfeyzi's post
  • Administrator , Dell_Brett, CAMSECT, oanm2000, Umer.Aleem
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
08-27-2025, 03:39 AM
concrete solution advocate
[-] The following 4 users Like concreteok's post:4 users Like concreteok's post
  • zrilek, Dell_Brett, oanm2000, subin91
  Corrosion of Steel In Concrete: Understanding, investigation and repair Grunf 12 8,083 12-25-2022, 10:10 PM
Last Post: carolinandra
  CS TR 69 - Repair of concrete structures with reference to BS EN 1504 ir_71 2 3,128 02-06-2022, 12:32 PM
Last Post: babakfeyzi
  Concrete Repair: A Practical Guide cace-01 6 5,038 02-06-2022, 11:44 AM
  CEB B243: Strategies for Testing and Assessment of Concrete Structures affected by... peixoto 1 3,447 06-17-2020, 12:51 AM
  Concrete Repair to EN 1504: Diagnosis, Design, Principles and Practice r3be1 3 3,623 11-16-2019, 09:08 AM
  Seismic Assessment and Retrofit of Reinforced Concrete Columns amindoxiti 0 2,224 04-12-2019, 12:11 PM
  Appraisal and Repair of Reinforced Concrete febo927 0 2,146 07-16-2018, 08:06 PM
Last Post: febo927
