Civil Engineering Association eBooks Structural Books Concrete Guidelines for the Simplified Design of Structural Reinforced Concrete for Buildings
 killoobilloo
User ID: 8644
Threads: 6
Likes: 255 in 17 posts
Given Likes: 237
12-03-2009, 06:09 PM (This post was last modified: 08-01-2011, 07:43 PM by Grunf.)
The aim of this International Standard is to provide rules for the design and construction of low-rise concrete
structures of small area to be built in the less developed areas of the world. The document is developed for
countries that do not have existing national standards. This document shall not be used in place of a national
standard unless specifically considered and accepted by the national standard body or other appropriate
regulartory organization. The design rules are based in simplified worldwide-accepted strength models. The
document is self-contained; therefore actions (loads) and simplified analysis procedures are included, as well as
minimum acceptable construction practice guidelines.
The minimum dimensional guidelines contained in this document are intended to account for undesirable side
effects that will require more sophisticated analysis and design procedures. Material and construction guidelines
are aimed at site mixed concrete as well as ready-mixed concrete, and steel of the minimum available strength
grades.
The earthquake resistance guidelines are included to account for the fact that numerous underdeveloped regions
of the world lay in earthquake prone areas. The earthquake resistance is based upon the employment of structural
concrete walls (shear walls) that limit the lateral deformations of the structure and provide for its lateral strength.
The document contains guidelines that can be modified by the national standards body due to local design and
construction requirements and practices. These guidelines that can be modified are included using ["boxed
values"]. The authorities in each member country are expected to review the "boxed values" and may substitute
alternative definitive values for these elements for use in the national application of the document.
A great effort was made to include self-explanatory tables, graphics, and design aids to simplify the use of the
document and provide foolproof procedures. Notwithstanding, the economic implications of the conservatism
inherent in approximate procedures as a substitution to sound and experienced engineering should be a matter of
concern to the designer that employs the document, and to the owner that hires him.
link by AG. NAYEL
[-] The following 41 users Like killoobilloo's post:41 users Like killoobilloo's post
  • Ultra Zone, Dell_Brett, rendel_©, leithowsky, babak, rcnet, nuttapolk, kowheng, ivanveliki, zrilek, essam2109, Grunf, amaranu, engr1900, ruaumoko, oanm2000, henrycv, w64bit, subin91, simanta, piseth, yutt, kaungthant, korneliusl, jcoronellr, vvvv, jorgeramos, baikur, joannaking, PAQS, cristi, tecnatech, boycv, Nilupa, kristoffer_89, shaqee, civilphongvan, 88FeNIX, Clouseau, rkce, tuanpecc1
 abouferass88
Yemen
User ID: 11928
Threads: 47
Likes: 598 in 75 posts
Given Likes: 237
08-01-2011, 09:34 PM
ISO Standard Guidelines for the Simplified Design of Structural Reinforced Concrete
Mirror Link:
[-] The following 33 users Like abouferass88's post:33 users Like abouferass88's post
  • ISTRAKTURA, gatob, simanta, mgdario, masafi_15, malc, blaze, 88FeNIX, techno, dbsimon29, Jackass, Clouseau, Dell_Brett, tluc, knrsa, seriousboy, yphani222, Trishu999, rkce, DamaD, concreteok, sodapas, salahcivil, zrilek, chenamoy, vardan, sacem, wa_sin_29, jayborre, batata666, GMianG, lednar_ved, cace-01
Away  bridgeengineer
Semi Senior Member
Banned
Poland
User ID: 93214
Threads: 49
Likes: 1,023 in 110 posts
Given Likes: 4769
12-25-2022, 01:25 PM
please reupload
thanks
 rami1976
User ID: 34597
Threads: 341
Likes: 9,523 in 1,137 posts
Given Likes: 1387
12-28-2022, 09:55 PM (This post was last modified: 12-28-2022, 09:57 PM by rami1976.)
Mirror
[-] The following 9 users Like rami1976's post:9 users Like rami1976's post
  • Dell_Brett, zrilek, melekeen, cace-01, bridgeengineer, milova, mgdario, tuanpecc1, oanm2000
  Design and Detailing of Low-Rise Reinforced Concrete Buildings Base on ACI318-14 poolmand 1 3,461 10-14-2024, 07:54 AM
  Reinforced Concrete Design sabooryan 7 7,227 04-29-2024, 05:01 AM
  Design of Reinforced Concrete Silo Groups carolinandra 2 3,933 04-25-2023, 10:31 AM
  Seismic Retrofit of Existing Reinforced Concrete Buildings carolinandra 0 2,937 02-05-2023, 08:00 PM
Last Post: carolinandra
  Illustrated Design of Reinforced Concrete Buildings (Design of G+3 Storeyed Buildings poolmand 3 4,767 12-29-2022, 06:01 AM
Last Post: amaranu
  CEB: Seismic Design of reinforced concrete structures for controlled inelastic respon lamkin 8 5,865 12-26-2022, 10:50 AM
  Reinforced and prestressed Concrete Design to EC2 - The complete Process gianniorlati 3 3,142 12-20-2022, 08:37 AM
Last Post: Dell_Brett
