Civil Engineering Association eBooks Structural Books Steel Australia Steel Institute Design Guide
 leong8929
User ID: 786
Threads: 34
Likes: 385 in 18 posts
Given Likes: 7
08-23-2012, 02:01 PM (This post was last modified: 08-23-2012, 02:08 PM by leong8929.)
Design Guide 1: Bolting in structural steel connections
Author: Hogan, T. J. and Munter, S. A. | Size: 5 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 2007-01-01 | pages: 64 | ISBN: 9780909945978
[Image: 24021053720745647563.jpg]
Design Guide 1 contains both design information and practical information on the types of structural bolts used in structural steel connections in Australia at the present time.
The design guide provides information on dimensions, design, specifications for bolts, certification of bolts, fabrication and erection issues related to bolts and bolting. It is aligned with AS 4100-1998 and supersedes AISC "Bolting of steel structures", 3rd ed., 1990.
Design Guide 2: Welding in structural steel connections
Author: Hogan, T. J. and Munter, S. A. | Size: 6 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 2007-01-01 | pages: 68 | ISBN: 9780909945992
[Image: 33321511642950448017.jpg]
Design Guide 2 contains practical information on the welding processes used to fabricate structural steel connections in Australia at the present time.
It does not however contain design information. The guide is aligned with AS 4100-1998 and AS 1554.1-2004 and is intended to be a basic primer on all aspects of welding as applied to structural steel connections.
Design Guide 3: Web side plate connections
Author: Hogan, T. J. and Munter, S. A. | Size: 6 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 2007-01-01 | pages: 60 | ISBN: 9780909945954
[Image: 41525780730807086723.jpg]
Design Guide 3 covers the web side plate connection, a simple connection in terms of AS 4100-1998. It references Handbook 1 for a number of design solutions used in the recommended Design Model for the web side plate connection and is aligned with AS 4100-1998.
The design guide describes the web side plate connection, provides generalised detailing for the connection, a recommended design model involving 10 separate design checks, two design examples and 6 design capacity tables derived for a selected geometry using the recommended design model. This publication supersedes two sections in AISC "Design of structural connections" by Hogan, T. J. and Thomas, I. R., 1994.
Design Guide 4: Flexible end plate connections
Author: Hogan, T. J. and Munter, S. A. | Size: 2 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 2007-01-01 | pages: 46 | ISBN: 9780909945961
[Image: 63758262574533833651.jpg]
Design Guide 4 covers the flexible end plate connection which is a simple connection in terms of AS 4100-1998. It references Handbook 1 for a number of design solutions used in the recommended Design Model for this connection.
Design Guide 4 describes the flexible end plate connection, provides generalised detailing for the connection, a recommended design model involving ten separate design checks, one design example and four design capacity tables derived for a selected geometry using the recommended design model.
Design Guide 5: Angle cleat connections
Author: Hogan, T. J. and Munter, S. A. | Size: 9 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 2007-01-01 | pages: 73 | ISBN: 9780980401523
[Image: 56832279319657120116.jpg]
Design Guide 5 covers the single and double angle cleat connection which is a simple connection in terms of AS 4100-1998. It references Handbook 1 for a number of design solutions used in the recommended Design Model for the angle cleat connection.
This design guide describes the connection, provides generalised detailing for the connection, a recommended design model for both single and double angle cleats, each involving ten separate design checks, two design examples and ten design capacity tables derived for a selected geometry using the recommended design model.
Design Guide 6: Seated connections
Author: Hogan, T. J. and Munter, S. A. | Size: 8 MB | Format: PDF | Quality: Scanner | Publisher: Australian Steel Institute | Year: 2007-01-01 | pages: 102 | ISBN: 9780980401561
[Image: 37577101118668215779.jpg]
Design Guide 6 covers four types of seated connections which are all simple connections in terms of AS 4100-1998. It references Handbook 1 for a number of design solutions used in the recommended Design Models for seated connections.
This design guide describes each type of seated connection, provides generalised detailing for the connection, a recommended design model for each, one design example for each connection type but no design capacity tables.
[-] The following 33 users Like leong8929's post:33 users Like leong8929's post
  • dovsky, avscorreia, malc, david-smith, miquan, ikoleci, radirob, odiclas, Hengki, jcoronellr, duazo2009, tomtumx, betinnn, adams, Dell_Brett, wanwin, pingfan2, Jackass, subin91, shadabg, toddyi, cace-01, cristi, seriousboy, durden, l_namali, monter, danphillips, hodzicemir, jcbv, promo8, inge911, femana
08-24-2012, 06:59 AM
Design Guide 1:
Design Guide 2:
Design Guide 3:
Design Guide 4:
Design Guide 5:
Design Guide 6:
[-] The following 6 users Like shadabg's post:6 users Like shadabg's post
  • agelos100, david-smith, melekeen, Dell_Brett, harsono, hodzicemir
 albani
Semi Senior Member
User ID: 23104
Threads: 11
Likes: 683 in 78 posts
Given Likes: 1025
08-24-2012, 08:15 AM
Mirror with all the 6 Design Guides:
If you can't run, keep walking.
[-] The following 20 users Like albani's post:20 users Like albani's post
  • david-smith, abhijit, zrilek, Dell_Brett, slowet, ruaumoko, harsono, xdesi, Matt89, jamalsbaih, cowboy, yanburak, hodzicemir, gulilero, jcbv, simanta, blaze, dinu69in, psk62, bridgeengineer
 enghitman
Egypt
User ID: 95044
Threads: 2
Likes: 5 in 3 posts
Given Likes: 1
05-04-2015, 02:45 PM
Hello,,
Can anyone upload the rest of design guides developed by ASI as it becomes 27 Design Guides till now,,i searched the forum and i did not find except these 6 design guides.
[-] The following 3 users Like enghitman's post:3 users Like enghitman's post
  • adams, jhaws, durden
  Australia Steel Institute - Design capacity tables for structural steel leong8929 5 6,242 12-26-2022, 10:41 AM
  Australia Steel Ins Design example for multistorey composite steel framed building leong8929 2 3,256 01-18-2020, 05:45 PM
Last Post: monter
  AISC Design Guide 35 Steel-Framed Storm Shelters sabooryan 0 1,705 09-05-2019, 06:08 PM
Last Post: sabooryan
  Design guide for concrete-filled double skin steel tubular structures carolinandra 0 1,518 04-16-2019, 04:02 PM
Last Post: carolinandra
  SCI P130: Building Design Using Cold Formed Steel Sections: An Architect’s Guide muqiang 2 2,683 01-11-2014, 06:25 PM
Last Post: arshiakh
  Australia Steel Institute Handbook 1 leong8929 1 2,091 08-24-2012, 06:38 AM
Last Post: shadabg
  Bracing Cold-Formed Steel Structures: A Design Guide (Incomplete) Vladimir 1 2,316 04-22-2012, 03:06 PM
Last Post: david-smith
