Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM C1609-10 Standard Test Method for Flexural Performance of Fiber-Reinforced Concr
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
08-09-2012, 12:04 AM
ASTM C1609-10 Standard Test Method for Flexural Performance of Fiber-Reinforced Concrete (Using Beam With Third-Point Loading)
Author: ASTM | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: ASTM | Year: 2010 | pages: 9
This test method evaluates the flexural performance of
fiber-reinforced concrete using parameters derived from the
load-deflection curve obtained by testing a simply supported
beam under third-point loading using a closed-loop, servocontrolled
testing system
[-] The following 11 users Like miquan's post:11 users Like miquan's post
  • kowheng, malc, Jackass, ir_71, utan, st77bel, lisine, peixoto, simanta, datagap, kiskertlugas
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,792 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,135 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,915 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,976 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,177 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 2,787 11-04-2023, 10:57 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,236 11-01-2023, 07:18 AM
