Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D4944 - 11 Standard Test Method for Field Determination of Water (Moisture) Con
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
08-08-2012, 04:15 PM (This post was last modified: 08-09-2012, 12:42 PM by oanm2000.)
ASTM D4944 - 11 Standard Test Method for Field Determination of Water (Moisture) Content of Soil by the Calcium Carbide Gas Pressure Tester
Author: ASTM | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: ASTM | Year: 2011 | pages: 6
This test method outlines procedures for determining the water (moisture) content of soil by chemical reaction using calcium carbide as a reagent to react with the available water in the soil producing a gas. A measurement is made of the gas pressure produced when a specified mass of wet or moist soil is placed in a testing device with an appropriate volume of reagent and mixed
[-] The following 12 users Like miquan's post:12 users Like miquan's post
  • 3fan, st77bel, david-smith, devilmaycry, kowheng, malc, Jackass, ir_71, utan, oanm2000, lisine, peixoto
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,765 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,109 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,882 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,943 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,146 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 2,749 11-04-2023, 10:57 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,203 11-01-2023, 07:18 AM
