Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Alternate Path method in progressive collapse analysis: Variation of dynamic and non-
[Request] Alternate Path method in progressive collapse analysis: Variation of dynamic and non-
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
06-02-2012, 07:36 AM (This post was last modified: 06-02-2012, 08:25 AM by lisine.)
Alternate Path method in progressive collapse analysis: Variation of dynamic and non-linear load increase factors
Author: Aldo E McKay (Author) | Size: ? MB | Format: PDF | Quality: Unspecified | Publisher: ProQuest, UMI Dissertation Publishing | Year: 2011 | pages: 86 | ISBN: 1243451807-978-1243451804
[Image: 92955324576166853139.jpg]
As a result of the increasing number of terrorist attacks registered against American facilities in the United States or abroad, United States government agencies continue to improve the design of their buildings to make them safer and less vulnerable to terrorist attacks. One of the factors typically considered in designing safer buildings and structures, is their ability to prevent total collapse after the loss of load-carrying components (Progressive Collapse) resulting from a terrorist attack. The consequences of not having a building capable of reducing the potential for progressive collapse could be catastrophic, as it was the case of the Oklahoma City bombing in 1995 where 42% of the Alfred P. Murrah Federal Building was destroyed by progressive collapse and only 4% by the explosion or blast. This attack claimed 168 lives and left over 800 injured. Over the last 10 years, two United States government agencies have developed guidelines for the design of their structures to resist progressive collapse: (1) The General Services Administration, "Progressive Collapse Analysis and Design Guidelines," (GSA Guidelines) and (2) The Department of Defense Unified Facilities Criteria 4-023-03 "Design of Buildings to Resist Progressive Collapse" (UFC 4-023-03). Within both approaches, the main direct design procedure is the Alternate Path (AP) method, in which a structure is analyzed for collapse potential after the removal of a column or section of wall. Different analytical procedures may be used, including Linear Static (LS), Nonlinear Static (NLS), and Nonlinear Dynamic (NLD). Typically, NLD procedures give better and more accurate results, but are more complicated and expensive. As a result, designers often choose static procedures, which tend to be simpler, requiring less labor. As progressive collapse is a dynamic and nonlinear event, the load cases for the static procedures require the use of factors to account for inertial and nonlinear effects, similar to the approach used in ASCE Standard 41 "Seismic Rehabilitation of Existing Buildings" (ASCE 41). A number of inconsistencies have been indentified in the way the existing guidelines applied dynamic and non-linear load factors to their static approaches. As part of an existing effort to update the existing guidelines, this study used SAP2000 to perform several AP analyses on a variety of Reinforced Concrete and Steel Moment Frame buildings to investigate the magnitude and variation of the dynamic and non-linear load increase factors. The study concluded that the factors in the existing guidelines tend to yield overly conservative results, which often translate into expensive design and retrofits. This study indentified new load increase factors and proposes a new approach to utilize these factors when performing AP analyses for Progressive Collapse.
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
06-03-2012, 05:53 PM
see
[-] The following 2 users Like hich's post:2 users Like hich's post
  • david-smith, Clouseau
  [REQUEST] Dynamic Analysis of Skeletal Structures: Force and Displacement Methods and Iterativ Saze808 0 1,342 11-18-2014, 06:21 PM
Last Post: Saze808
  [REQUEST] Finite Strip Method in Structural Analysis, Finite Strip Method louislouis 1 1,546 11-03-2014, 03:34 PM
Last Post: ssobhan
  [REQUEST] Nonlinear dynamic analysis of three dimensional base isolated structures ali akbar 0 1,335 03-08-2014, 03:14 PM
Last Post: ali akbar
  [REQUEST] Progressive collapse analysis of high rise building hmwere 2 2,219 02-08-2013, 08:39 AM
  Investigation of progressive collapse resistance and inelastic response of Earthquake NAUTILUS87 2 2,444 02-07-2013, 02:27 PM
Last Post: devilmaycry
  [REQUEST] ANALYSIS OF TRANSMISSION TOWER DYNAMIC CHARACTERISTIC apocalipse 0 1,402 12-06-2012, 11:18 PM
Last Post: apocalipse
  [REQUEST] Detection on collapse of a box-culvert and analysis on its causation raffah 0 1,311 09-06-2012, 10:09 AM
Last Post: raffah
