Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D4719 - 07 Standard Test Methods for Prebored Pressuremeter Testing in Soils
06-01-2012, 04:29 AM (This post was last modified: 06-01-2012, 09:26 AM by mybest.)
Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: ASTM | Year: 2007 | pages: 9
This test method provides a stress-strain response of the soil in situ. A pressuremeter modulus and a limit pressure is obtained for use in geotechnical analysis and foundation design.
The results of this test method are dependent on the degree of disturbance during drilling of the borehole and insertion of the pressuremeter probe. Since disturbance cannot be completely eliminated, the interpretation of the test results should include consideration of conditions during drilling. This disturbance is particularly significant in very soft clays and very loose sands. Disturbance may not be eliminated completely but should be minimized for the prebored pressuremeter design rules to be applicable.
Recreate using Post Generator, Split - mybest
  • utan, blaze, kowheng, Dell_Brett, cace-01, oanm2000, 2824, toa011, nhim4mat2006
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,792 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,136 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,915 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,976 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,177 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 2,787 11-04-2023, 10:57 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,236 11-01-2023, 07:18 AM
