Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D1587: Standard Practice for Thin-Walled Tube Sampling of Soils for Geotechn
04-18-2011, 04:28 PM (This post was last modified: 01-23-2022, 10:35 AM by Administrator.)
ASTM D1587 – 08 Standard Practice for Thin-Walled Tube Sampling of Soils for Geotechnical Purposes
Author: ASTM Committee D18 | Size: 0.07 MB | Format: PDF | Publisher: ASTM | Year: 2008 | pages: 4
[Image: 57182245433286671941.jpg]
1.1 This practice covers a procedure for using a thin-walled metal tube to recover relatively intact soil samples suitable for laboratory tests of engineering properties, such as strength,
compressibility, permeability, and density. Thin-walled tubes used in piston, plug, or rotary-type samplers should comply with Section 6.3 of this practice which describes the thinwalled
tubes.
NOTE 1—This practice does not apply to liners used within the samplers.
1.2 This Practice is limited to soils that can be penetrated by the thin-walled tube. This sampling method is not recommended for sampling soils containing gravel or larger size soil
particles cemented or very hard soils. Other soil samplers may be used for sampling these soil types. Such samplers include driven split barrel samplers and soil coring devices (D1586, D3550, and D6151). For information on appropriate use of other soil samplers refer to D6169.
1.3 This practice is often used in conjunction with fluid rotary drilling (D1452, D5783) or hollow-stem augers (D6151). Subsurface geotechnical explorations should be reported in accordance with practice (D5434). This practice discusses some aspects of sample preservation after the sampling event. For information on preservation and transportation
process of soil samples, consult Practice D4220. This practice does not address environmental sampling; consult D6169 and D6232 for information on sampling for environmental investigations.
1.4 The values stated in inch-pound units are to be regarded as standard. The values given in parentheses are mathematical conversions to SI units that are provided for information only and are not considered standard.
1.4.1 The tubing tolerances presented in Table 1 are from sources available in North America. Use of metric equivalent is acceptable as long as thickness and proportions are similar to those required in this standard.
1.5 This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate
safety and health practices and determine the applicability of regulatory limitations prior to use.
1.6 This practice offers a set of instructions for performing one or more specific operations. This document cannot replace education or experience and should be used in conjunction with professional judgment. Not all aspects of this practice may be applicable in all circumstances. This ASTM standard is not intended to represent or replace the standard of care by which the adequacy of a given professional service must be judged, nor should this document be applied without consideration of a project’s many unique aspects. The word “Standard” in the title of this document means only that the document
[-] The following 3 users Like ir_71's post:3 users Like ir_71's post
  • kowheng, oanm2000, pelelo
ASTM D1587 – 15 Standard Practice for Thin-Walled Tube Sampling of Soils for Geotechnical Purposes
  • babakfeyzi, Dell_Brett, kowheng, oanm2000, utan
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,792 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,135 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,915 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,976 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,177 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,236 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 2,810 10-28-2023, 06:32 AM
