Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 6798:2009 Specification for installation and maintenance of gas-fired boilers of r
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
12-11-2011, 10:20 AM
BS 6798:2009 Specification for installation and maintenance of gas-fired boilers of rated input not exceeding 70 kW net
Size: 383 KB | Format: PDF | Year: 31 January 2009 | pages: 46 | ISBN: 978 0 580 61900 7
[Image: 78459196633348494979.png]
BS 6798:2009 specifies requirements for the selection, installation, inspection, commissioning and maintenance of gas‑fired boilers for central heating and other purposes, which have a total rated heat input not exceeding 70 kW, based on net calorific value. This includes cookers with integral boilers used to provide central heating.
It applies to boilers utilizing 1st, 2nd or 3rd family gases designed to operate in the condensing or non‑condensing mode for the heating of domestic dwellings or domestic dwellings in commercial premises by the circulation of heated water in open or closed systems. It applies both to boilers which carry a CE mark and also to previously used boilers which do not carry the CE mark.
BS 6798 gives recommendations on:
Selection of equipment and pre‑installation
Installation
Post‑installation.
In line with BS 5440-1 , this revision has acknowledged that European work on chimney standards has brought about the need in British
Standards to redefine chimney concepts and adopt common terminology consistent with the range of products used across the whole European community where a chimney is treated as a structure containing a flue (the passageway) and might include a liner (inner wall), insulation and an outer wall. The common terminology in UK industry, which has regarded a chimney as a masonry structure generally associated with solid fuel appliances, has been superseded.
BS 6798:2009 supersedes BS 6798:2000, which is withdrawn.
Made By CivilEA Post-Generator ver 2.1.2
[-] The following 7 users Like mybest's post:7 users Like mybest's post
  • kowheng, Jackass, malc, peixoto, araza023, kvtasp, Dell_Brett
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
12-24-2011, 06:03 PM
[-] The following 1 user Likes kvtasp's post:1 user Likes kvtasp's post
  • Dell_Brett
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
02-26-2013, 07:10 AM
[-] The following 1 user Likes arshiakh's post:1 user Likes arshiakh's post
  • Dell_Brett
  BS 4515-1:2009 Specification for welding of steel pipelines on land and offshore mybest 2 3,033 07-17-2014, 02:11 AM
Last Post: legend2611
  BS 6173:2009 Specification for installation and maintenance of gas-fired mybest 2 2,447 02-26-2013, 07:13 AM
Last Post: arshiakh
  BS 6644:2011 Specification for the installation and maintenance of gas-fired hot wate mybest 2 2,481 02-26-2013, 07:02 AM
Last Post: arshiakh
  BS EN 13524:2003+A1:2009 Highway maintenance machines — Safety requirements ir_71 2 2,420 02-14-2013, 10:04 AM
  BS 6700:2006 Design, installation, testing and maintenance of services supplying wate ir_71 1 2,879 09-25-2012, 05:02 AM
