Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 6700:2006 Design, installation, testing and maintenance of services supplying wate
11-25-2010, 06:52 AM
BS 6700:2006 Design, installation, testing and maintenance of services supplying water for domestic use within buildings and their curtilages – Specification
Author: Committee reference B/504/2 | Size: 1.4 MB | Format: PDF | Publisher: BSI | Year: 2006 | pages: 146 | ISBN: 0 580 49786 0
[Image: 29864081325365737648.jpg]
This British Standard specifies requirements for and gives
recommendations on the design, installation, alteration, testing and
buildings and their curtilages. It covers the system of pipes, fittings and
connected appliances installed to supply any building, whether
domestic or not, with water for drinking, culinary, domestic laundry,
ablutionary, cleaning and sanitary purposes1).
This standard deals only with low temperature systems; it does not
cover systems that are designed to operate with steam or high
temperature hot water.
This standard does not cover domestic central heating systems.
Although many of its recommendations will be applicable, this standard
does not cover fire fighting services nor water supply for industrial or
other specialist purposes other than to indicate precautions that should
be taken when these are used in association with other water services.
The point at which a domestic activity becomes an industrial process,
e.g. in food preparation, has not been defined and the applicability of
this standard will need to be considered in each case.
  • kowheng, blaze, usman, zrilek, roaming79
09-25-2012, 05:02 AM
New working links:
  • mahyarov, blaze, malc, Jackass, lisine, zrilek, miquan
  BS EN ISO 22475-1:2006 part 1 Geotechnical Investigation and Testing ir_71 1 2,091 03-25-2015, 03:42 PM
Last Post: Mohammad6299
  BS 6173:2009 Specification for installation and maintenance of gas-fired mybest 2 2,447 02-26-2013, 07:13 AM
Last Post: arshiakh
  BS 6798:2009 Specification for installation and maintenance of gas-fired boilers of r mybest 2 2,587 02-26-2013, 07:10 AM
Last Post: arshiakh
  BS 6644:2011 Specification for the installation and maintenance of gas-fired hot wate mybest 2 2,480 02-26-2013, 07:02 AM
Last Post: arshiakh
