Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) PD 8010-1:2004 Code of practice for pipelines — Part 1: Steel pipelines on land
01-17-2011, 05:01 AM
Author: Technical Committee PSE/17 | Size: 2.51 MB | Format: PDF | Publisher: BSI | Year: 2004 | pages: 128 | ISBN: 0580439518
[Image: 12202302108883839971.jpg]
This part of PD 8010 gives recommendations for and guidance on the design, selection, specification and
use of materials, routing, land acquisition, construction, installation, testing, operation, maintenance and
abandonment of land pipeline systems constructed from steel. The principles of this part of PD 8010 apply
to new pipelines and major modifications to existing pipelines. It is not intended to replace or duplicate
hydraulic, mechanical or structural design manuals.
This part of PD 8010 is applicable to pipelines that may be used to carry oil, gas and other substances that
are hazardous by nature of being explosive, flammable, toxic, reactive, or liable to cause harm to persons
or to the environment. It covers pipelines operating at temperatures between a range of –25 °C and +120 °C
inclusive.
The extent of pipeline systems covered by this part of PD 8010 is shown in Figure 1.
NOTE Annex A shows the full range of onshore oil and gas pipeline systems covered by this part of PD 8010.
This part of PD 8010 does not give recommendations for subsea pipelines, which are covered in PD 8010-2.
  • kowheng, usman, blaze, almadar12, ssi3k, toa011, oanm2000, faros3000, zrilek, roaming79, rohailiyaz, k1k0k0, hcardenas, Dell_Brett, peixoto
10-07-2012, 05:01 AM
New links:
[-] The following 4 users Like ir_71's post:4 users Like ir_71's post
  • malc, Dell_Brett, Jackass, zrilek
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,380 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,602 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,251 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,129 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,383 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,749 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,317 02-17-2021, 11:20 AM
Last Post: temp1366
