Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 771 Standard series Specification for masonry units
11-15-2010, 05:47 PM
EN 771-1 Specification for masonry units - Part 1: Clay masonry units
This EN specifies the characteristics and performance requirements for masonry units manufactured from clay for use in masonry construction (e.g. facing and rendered masonry, loadbearing or non-loadbearing masonry structures, including internal linings and partitions, for building and civil engineering). This EN is intended to apply to all fired-clay masonry units used in masonry construction, including those of an overall non-rectangular parallelepiped shape.
EN 771-2+AC Specification for masonry units - Part 2: Calcium silicate masonry units
This EN specifies the characteristics and performance requirements of calcium silicate masonry units for which the main intended uses are inner walls, outer walls, cellars, foundations and chimneys, including those of an overall non-rectangular parallelepiped shape, specially shaped and accessory units.
EN 771-3 Specification for masonry units - Part 3: Aggregate concrete masonry units (Dense and light-weight aggregates)
This EN specifies the characteristics and performance requirements for the physical and mechanical properties of aggregate concrete masonry units made from dense aggregate, lightweight aggregate or a combination of both. Units conforming to this Part of this EN are used exposed or non-exposed in common or facing masonry in building or civil engineering works.
EN 771-4 Specification for masonry units - Part 4: Autoclaved aerated concrete masonry units
This EN specifies the characteristics and performance requirements of autoclaved aerated concrete (AAC) masonry units for which the main intended uses are different types of loadbearing and non-loadbearing applications in all forms of walling including single leaf, cavity, partitions, retaining, basement and general use below ground level, including walling for fire protection, thermal insulation, sound insulation and chimneys.
EN 771-5 Specification for masonry units - Part 5: Manufactured stone masonry units
This EN specifies the characteristics and performance requirements of Manufactured Stone Masonry Units for which the main intended uses are facing or exposed masonry in loadbearing or non-loadbearing building and civil engineering applications. The units are suitable for all forms of coursed or random masonry walling, including single leaf, cavity, partition, retaining and the external masonry to chimneys and they can provide fire protection, thermal insulation, sound insulation and sound absorption.
EN 771-6 Specification for masonry units - Part 6: Natural stone masonry units
This European Standard specifies the characteristics and performance requirements of masonry units manufactured from natural stone the width of which is equal to or greater than 80 mm, for which the main intended uses are common, facing or exposed masonry units in load bearing or non-load bearing building and civil engineering applications These units are suitable for all forms of coursed or random masonry walling, including single leaf, cavity, partition, retaining and the external masonry to chimneys. They can provide fire protection, thermal insulation, sound insulation and sound absorption.
This European Standard includes natural stone masonry units of an overall non-rectangular parallelipiped shape, specially shaped and accessory units for internal and external application.
It defines the performance related to e.g. strength, petrographic description, density, porosity, dimensional accuracy, thermal conductivity, water absorption, and frost resistance and provides for the evaluation of conformity of the product to this European Standard. The marking requirements for products covered by this European Standard are also included.
This European Standard does not cover storey height panels, natural stone for paving, chimney flue linings nor units intended for use as damp proof course.
:JC_cheers:
[-] The following 17 users Like ir_71's post:17 users Like ir_71's post
  • Grunf, kowheng, toa011, Dell_Brett, chigozie, oanm2000, ziggywas1, zrilek, roaming79, diotviet, pulikesi23rd, vvvv, scorpion07, vpmohammed, mig21, Jackass, warbeast
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
11-27-2011, 12:37 AM
As per request by PM by ir_71, I upload BS EN 771 2011
2 - BS EN 771-2 2011 - Specification for masonry units. Calcium silicate masonry units
3 - BS EN 771-3 2011 - Specification for masonry units. Aggregate concrete masonry units (dense and lightweight aggregates)
4 - BS EN 771-4 2011 - Specification for masonry units . Autoclaved aerated concrete masonry units
5 - BS EN 771-5 2011 - Specification for masonry units. Manufactured stone masonry units
6 - BS EN 771-6 2011 - Specification for masonry units . Natural stone masonry units
Dear ir_71
There is no BS EN 771-1 2011 in database. If you can be more detail, maybe I can help you.
mybest
[-] The following 13 users Like mybest's post:13 users Like mybest's post
  • kowheng, st77bel, vpmohammed, Grunf, ir_71, Jackass, NBZ1400, zrilek, peixoto, warbeast, Dell_Brett, falloutboy, datagap
 mybest
Indonesia
User ID: 32155
Threads: 283
Given Likes: 686
12-14-2011, 04:53 PM
BS EN 771-1:2011 is now available
Specification for masonry units. Clay masonry units
pass: pRiVaTEfoRCivilEA
[-] The following 8 users Like mybest's post:8 users Like mybest's post
  • ir_71, st77bel, kowheng, Jackass, Dell_Brett, vpmohammed, uetian19, falloutboy
 kurdelis
Lithuania
User ID: 86526
Threads: 0
Likes: 2 in 1 posts
Given Likes: 3
01-28-2014, 11:17 AM
Can somebody reupload this please?
[-] The following 2 users Like kurdelis's post:2 users Like kurdelis's post
  • abualamal, azbukvid
 CAMSECT
Cambodia
User ID: 175572
Threads: 1
Likes: 2 in 2 posts
Given Likes: 402
02-13-2022, 10:59 AM
please new link
  EN ISO 15630 Standard series Steel for the reinforcement and prestressing of concrete ir_71 5 5,809 02-15-2022, 08:36 AM
Last Post: zrilek
  EN 10028:2009 Flat Products Made of Steel for Pressure Purposes Standard series ir_71 1 2,298 03-12-2014, 05:50 PM
  EN 10244 Standard Series Steel wire and wire products - Non-ferrous metallic coatings ir_71 1 2,525 06-07-2013, 07:04 AM
  EN 10088 Stainless Steel standard series ir_71 2 3,228 11-20-2012, 10:19 AM
  EN 10083:2006 Standard Series - Steels for quenching and tempering ir_71 0 2,232 10-23-2010, 02:27 PM
