Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 10244 Standard Series Steel wire and wire products - Non-ferrous metallic coatings
10-24-2010, 10:23 AM
EN 10244 Stadard Series Steel wire and wire products - Non-ferrous metallic coatings on steel wire
EN 10244-1:2009 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 1: General principles
This part of this European Standard specifies the requirements for the mass, other properties and testing of non-ferrous metal coatings on steel wire and steel wire products of circular or other cross-section.
This European Standard deals with requirements of general application and is of use for those coatings for which no particular requirements have been laid down in the following parts (2 to 6). Deviations are possible, particularly if required for well-defined products. In such cases, appropriate requirements shall be part of the relevant product standard.
EN 10244-2:2009 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 2: Zinc or zinc alloy coatings
This part of this European Standard specifies the requirement for coating mass, other properties and testing of zinc and zinc alloy coatings on steel wire and steel wire products of circular or other section.
EN 10244-3:2001 Steel wire and wire products -Non-ferrous metallic coatings on steel wire - Part 3: Aluminium coatings
This part of this European Standard specifies the requirements for the mass, other properties and testing of aluminium coatings on steel wire and steel wire products of circular or other cross-section.
EN 10244-4:2001 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 4: Tin coatings
This part of this European Standard specifies the requirements for mass, other properties and testing of tin coatings on steel wire and steel wire products of round or other cross section.
EN 10244-5:2001 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 5: Nickel coatings
This part of this European Standard specifies the requirements for mass, other properties and testing of nickel coatings on steel wire and steel wire products of round or other cross-section.
EN 10244-6:2001 Steel wire and wire products - Non-ferrous metallic coatings on steel wire - Part 6: Copper, bronze or brass coatings
This part of this European Standard specifies the requirements for mass, other properties and testing of copper, bronze and brass coatings on steel wire and steel wire products.
  • kowheng, toa011, seriousboy, roaming79, imatoric, sivlad
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
06-07-2013, 07:04 AM
part 1,2,3,5 here
password:
[-] The following 4 users Like andersen3's post:4 users Like andersen3's post
  • Dell_Brett, blaze, Jackass, peixoto
  EN 10346:2009 Continuously hot-dip coated steel flat products Grunf 6 6,725 03-12-2022, 01:55 PM
Last Post: Kurucz
  EN ISO 15630 Standard series Steel for the reinforcement and prestressing of concrete ir_71 5 5,809 02-15-2022, 08:36 AM
Last Post: zrilek
  EN 771 Standard series Specification for masonry units ir_71 4 5,585 02-13-2022, 10:59 AM
Last Post: CAMSECT
  EN 10204:2004 Metallic products - Types of inspection documents ir_71 1 2,550 04-11-2014, 04:33 AM
  EN 10028:2009 Flat Products Made of Steel for Pressure Purposes Standard series ir_71 1 2,298 03-12-2014, 05:50 PM
  EN 10088 Stainless Steel standard series ir_71 2 3,228 11-20-2012, 10:19 AM
  EN 10168:2004 Steel products - Inspection documents - List of information and descrip ir_71 0 2,138 01-23-2011, 07:37 AM
