Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 10083:2006 Standard Series - Steels for quenching and tempering
10-23-2010, 02:27 PM
EN 10083:2006 Standard Series Steels for quenching and tempering
EN 10083-1:2006 Steels for quenching and tempering - Part 1: General technical delivery conditions
This part of EN 10083 specifies the general technical delivery requirements for
semi-finished products, hot formed, e.g. blooms, billets, slabs (see NOTES 2 and 3),
bars (see NOTE 2),
rod,
wide flats,
hot-rolled strip and sheet/plate,
forgings (see NOTE 2)
manufactured from the direct hardening non alloy steels for quenching and tempering (see EN 10083-2), the direct hardening alloy steels for quenching and tempering (see EN 10083-3), the non alloy flame and induction hardening steels (see EN 10083-2) and the alloy flame and induction hardening steels (see EN 10083-3), and supplied in one of the heat treatment conditions given for the different types of products in the relevant tables of EN 10083-2 and EN 10083-3 and in one of the surface conditions given in the relevant tables of EN 10083-2 and EN 10083-3.
The steels are generally intended for the manufacture of quenched and tempered, flame or induction hardened machine parts, but can also be used in the normalized condition (see EN 10083-2).
Where applicable, the requirements for mechanical properties given in EN 10083-2 and EN 10083-3 are restricted to the relevant tables in these documents.
NOTE 1 European Standards on similar grades are listed in Annex C.
NOTE 2 Hammer forged semi-finished products (blooms, billets, slabs etc.), seamless rolled rings and hammer forged bars are in the following covered under semi-finished products or bars and not under the term "forgings".
NOTE 3 Special agreements should be made when ordering un-worked continuously cast semi-finished products.
NOTE 4 In accordance with EN 10020, the steels covered by EN 10083-2:2006 are quality and special steels, the steels covered by EN 10083-3:2006 are special steels. The differences between quality and special steels are characterized by the following requirements, which are valid for special steels only:
the minimum impact values in the quenched and tempered condition (for non alloy special steels in the case of...
EN 10083-2:2006 Steels for quenching and tempering - Part 2: Technical delivery conditions for non alloy steels
This part of EN 10083, in addition to Part 1, specifies the technical delivery requirements for:
semi-finished products, hot formed, e.g. blooms, billets, slabs (see NOTES 2 and 3 in EN 10083-1:2006, Clause 1),
bars (see NOTE 2 in EN 10083-1:2006, Clause 1),
rod,
wide flats,
forgings (see NOTE 2 in EN 10083-1:2006, Clause 1),
manufactured from the direct hardening non alloy steels for quenching and tempering and the non alloy flame and induction hardening steels and supplied in one of the heat treatment conditions given for the different types of products in Table 1, lines 2 to 7, and in one of the surface conditions given in Table 2.
The steels are generally intended for the manufacture of quenched and tempered, flame or induction hardened machine parts, but can also be used in the normalized condition.
The requirements for mechanical properties given in this document are restricted to the sizes given in Table 9 and Table 10.
NOTE This document does not apply for bright steel products. For bright steel products EN 10277-1 and EN 10277-5 apply.
In special cases, variations in these technical delivery requirements or additions to them may be agreed at the time of enquiry and order (see Annex A).
EN 10083-3:2006 Steels for quenching and tempering - Part 3: Technical delivery conditions for alloy steels
rod,
wide flats,
manufactured from the direct hardening alloy steels for quenching and tempering and the alloy flame and induction hardening steels and supplied in one of the heat treatment conditions given for the different types of products in Table 1, lines 2 to 6, and in one of the surface conditions given in Table 2.
The steels are generally intended for the fabrication of quenched and tempered or induction hardened machine parts.
The requirements for mechanical properties given in this document are restricted to the sizes given in Table 8.
[-] The following 4 users Like ir_71's post:4 users Like ir_71's post
  • kowheng, jcbv, chenamoy, roaming79
  EN ISO 15630 Standard series Steel for the reinforcement and prestressing of concrete ir_71 5 5,799 02-15-2022, 08:36 AM
Last Post: zrilek
  EN 771 Standard series Specification for masonry units ir_71 4 5,567 02-13-2022, 10:59 AM
Last Post: CAMSECT
  EN 10028:2009 Flat Products Made of Steel for Pressure Purposes Standard series ir_71 1 2,290 03-12-2014, 05:50 PM
  EN 10244 Standard Series Steel wire and wire products - Non-ferrous metallic coatings ir_71 1 2,516 06-07-2013, 07:04 AM
  EN 10088 Stainless Steel standard series ir_71 2 3,225 11-20-2012, 10:19 AM
