Civil Engineering Association eBooks Traffic Engineering Thickness Design for Concrete Highway and Street Pavements Canadian Edition
11-15-2010, 10:46 AM
[Image: 33964959889426571218.jpg]
This bulletin deals with methods of determining slab thicknesses adequate to carry traffic loads on concrete streets, roads, and highways. The design purpose is the same as for other engineered structures-to find the minimum thickness that will result in the lowest annual cost as shown by both first cost and maintenance costs. If the thickness is greater tl~an needed, the pavement will give good service with low maintenance costs, but first cost will be high. If the thickness is not adequate, premature and costly maintenance and interruptions in traffic will more than offset the lower first cost. Sound engineering requires thickness designs that properly balance first costs and maintenance costs. While this bulletin is confined to the topic of thickness design, other design aspects are equally important to ensure the performance and long life of concrete pavements. These il~clude- Provision for reasonably uniform subgrade support. (See Reference 1 for additional detail.) Prevention of mud-pumping or faulting with a relatively thin untreated or cement-treated subbase on projects where the expected truck traffic will be great enough to cause pumping. (The need for and equirements of subbase are described in References 1, 2, and 3.) Use of a joint design that will afford adequate load transfer, control cracking, and prevent joint distress due to infiltration. ("5) Use of a concrete mix design and aggregates that will provide quality concrete wit11 the strength and durability needed for long life under the actual exposure
conditions. (6) The thickness design criteria suggested are based on general pavement performance experience. If regional or local specific performance experience becomes available for more favorable or adverse conditions, the design criteria can be appropriately modified. This could be the case for particular climate, soil, or drainage conditions and
future design innovations.
[-] The following 20 users Like ir_71's post:20 users Like ir_71's post
  • kowheng, Dell_Brett, toa011, isurya, cace-01, shanta, Octavio, sasan7351, oanm2000, hazus, usman, duazo2009, fer962933, narendra, Jackass, gulilero, sodapas, dinu69in, subin91, plngage
08-13-2011, 10:10 AM (This post was last modified: 12-31-2011, 08:04 AM by kowheng.)
PDF|RAR 3.22|3.13 MB
RAR password: KCivilEA
[-] The following 8 users Like kowheng's post:8 users Like kowheng's post
  • Dell_Brett, malc, knrsa, cristi, Jackass, tumangik, oanm2000, isurya
 subin91
Semi Senior Member
User ID: 2232
Threads: 35
Likes: 2,192 in 111 posts
Given Likes: 4684
08-21-2015, 01:50 AM
Mirror Link
[-] The following 14 users Like subin91's post:14 users Like subin91's post
  • mgdario, odiclas, gulilero, malc, PinkPant, f_slikken, Dell_Brett, bridgeengineer, oanm2000, sodapas, karroumk, febo927, Hengki, Nita1391
  Principles of Highway Engineering and Traffic Analysis (5th Edition) cace-01 3 5,132 01-20-2022, 01:01 PM
Last Post: cace-01
  Traffic and Highway Engineering, Enhanced Edition 5th Edition ir_71 11 6,991 11-22-2021, 06:58 AM
  Highway and Traffic Engineering in Developing Countries - 1st Edition febo927 0 2,861 09-26-2018, 05:25 PM
Last Post: febo927
  Structural Behavior of Asphalt Pavements - 1st Edition febo927 1 2,848 06-27-2018, 05:32 AM
Last Post: axcel
  Highways: The Location, Design, Construction and Maintenance of Road Pavements abudabeeja 6 5,221 06-19-2016, 09:57 AM
  Highway Engineering: Pavements, Materials and Control of Quality cace-01 1 1,924 07-19-2015, 05:17 PM
Last Post: gulilero
  Urban Design: Street and Square, Third Edition AARONSTACK 3 3,031 01-31-2015, 05:37 PM
Last Post: Veggeta
