Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 6297:2007 Code of practice for the design and installation of drainage fields for
11-03-2010, 05:22 PM
BS 6297:2007 Code of practice for the design and installation of drainage fields for use in wastewater treatment
BS 6297 gives recommendations and guidance on the design and installation of drainage fields and infiltration systems for use in wastewater treatment. BS 6297 is applicable to systems for handling discharges from domestic and commercial sources from single households and upwards. These sources are typically septic tanks and package treatment plants.
This Code of Practice gives general advice on good design and installation practices. Particular requirements are determined by local conditions. The recommendations are supplemented, as required, by specialist advice.
Who should use BS 6297?
Designers
Specifiers and procurement officers
Pollution and building control officers
Local authorities
Environment agencies
Manufacturers of small wastewater treatment systems
Table of Contents
Scope
Normative references
Terms and definitions
Drainage fields
Preliminary planning, site investigation and assessment
Detailed system design
Components
Construction of drainage field
Maintenance
Annex A (informative) Plants as drainage indicators
Annex B (informative) Regulatory requirements
Annex C (informative) Alternative disposal methods
Bibliography
List of figures
List of tables
BS 6297 has been amended and replaces BS 6297:1983 which is now withdrawn.
:JC_cheers:
  • toa011, lcruzz, allagui10, kowheng, oanm2000, roaming79
09-22-2012, 04:37 AM
Author: Committee B/505 | Size: 0.44 MB | Format: PDF | Quality: Original preprint | Publisher: BSI | Year: 2007 | pages: 44 | ISBN: 9780580607561
[Image: 38138220505495845805.jpg]
Please, see above.
  • blaze, malc, lisine, Jackass, knrsa, st77bel, miquan, dinu69in, Trishu999, royal_eagle
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
01-29-2015, 05:47 AM
password
  • concreteok, lisine, Dell_Brett, PinkPant, oanm2000, zrilek
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 402
01-29-2015, 04:35 PM
[-] The following 3 users Like Veggeta's post:3 users Like Veggeta's post
  • oanm2000, PinkPant, hodzicemir
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,376 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,593 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,238 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,127 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,379 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,745 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,313 02-17-2021, 11:20 AM
Last Post: temp1366
