Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8004:1986 Code of practice for foundations
11-03-2010, 05:22 AM (This post was last modified: 01-26-2014, 10:34 AM by Grunf.)
BS 8004:1986
Status : Superseded, Withdrawn Published : September 1986
Design and construction of foundations for the normal range of buildings and engineering structures, excluding foundations for special structures. General design, shallow, deep and subaqueous foundations, cofferdams and caissons, pile foundations; guidance on geotechnical processes; also tide work, underwater concreting, diving and site preparation for foundation work. Durability of timber, metal and concrete structures. A special reference is made to safety precautions.
Replaced By BS EN 1997-1:2004
[-] The following 19 users Like ir_71's post:19 users Like ir_71's post
  • kowheng, hmwere, zrilek, isurya, super_engineer, sashka.od, toa011, oanm2000, Dell_Brett, Adam Smith, simanta, eng-bg2009, adshrt, utan, nhim4mat2006, sivlad, peixoto, Evandrojr, tuanpecc1
 adshrt
User ID: 8297
Threads: 36
Likes: 1,203 in 114 posts
Given Likes: 364
07-11-2011, 03:16 PM (This post was last modified: 01-26-2014, 10:34 AM by Grunf.)
above link dead
[-] The following 4 users Like adshrt's post:4 users Like adshrt's post
  • NBZ1400, nhim4mat2006, sivlad, utan
07-11-2011, 05:52 PM (This post was last modified: 01-26-2014, 10:35 AM by Grunf.)
Author: Committee B/526 | Size: 2.7 MB | Format: PDF | Publisher: BSI | Year: 1986 | pages: 160 | ISBN: 0580151662
This British Standard code of practice gives recommendations for the design and construction of foundations for the normal range of buildings and engineering structures.
Section two covers the general principles of design; sections three, four, five and seven are concerned with more detailed considerations of the design and installation of the main types of foundations. Sections six, eight and nine relate to site operations and construction processes involved in foundation engineering and section ten describes the factors affecting the durability of the various materials used in foundation structures. Section eleven covers safety precautions. The Standard does not cover foundations for special structures.
This code of practice takes into account the often wide range of solutions to the day to day problems that face those having to take decisions on foundation works and provides recommendations based on commonsense principles to provide the most appropriate and cost effective solution for the satisfactory completion of the Works.
  • adshrt, 3fan, gatob, oanm2000, Dell_Brett, Jackass, malc, utan, nhim4mat2006, zrilek, lasalleguy, isurya, grass, cleopie71, sivlad, nik.firmann, deltalead, Batman07
10-11-2012, 04:52 AM (This post was last modified: 01-26-2014, 10:35 AM by Grunf.)
New links:
  • versiondemo, lisine, Dell_Brett, Jackass, zrilek, knrsa
01-25-2014, 09:28 PM
Found online here:
[-] The following 13 users Like Grunf's post:13 users Like Grunf's post
  • malc, geomahesh, Dell_Brett, ting tsai huang, cordoba123, 2824, Evandrojr, osw90, zrilek, uetian19, blaze, alibouafia, rizal13
07-17-2016, 05:28 AM
BS 8004:2015 Code of practice for foundations
[Image: 57843605741632173991.jpg]
  • Author(s): Technical Committee B/526 "Geotechnics"
  • Published By: BSI
  • Published Year: June 2015
  • Size: 1.10 MB
  • Quality: Original preprint
  • Abstract: This British Standard gives recommendations for the design and construction of foundations for the normal range of buildings and engineering structures. It provides non-contradictory, complementary information for use in conjunction with BS EN 1997 and its UK National Annex.
    Clause 4 gives general recommendations for the design and construction of all types of foundations;
    Clause 5 and Clause 6 give specific recommendations for the design and construction of spread foundations and pile foundations (respectively).
    Annex A gives specific recommendations for the design and construction of helical steel piles.
    Annex B gives specific recommendations for the design and construction of underpinning.
    Annex C gives information about specific geological formations encountered in the UK.
    Annex D gives information about the UK Government’s policy regarding archaeological finds.
MODERATOR NOTE: MEGAZ link needs a encryption key --> INCOMPLETE LINK
  • eng donny, slowet, civilfafa, zrilek, concreteok, isurya, oanm2000, Jackass, karthikeyans3d, malc, PinkPant, monter, andersen3, bao2004, peixoto, alibouafia, blaze, tuanpecc1
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,380 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,600 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,246 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,129 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,383 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,748 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,317 02-17-2021, 11:20 AM
Last Post: temp1366
