Civil Engineering Association eBooks Codes, Manual & Handbook Wood Design Manual 2005
 toa011
User ID: 9336
Threads: 135
Likes: 6,122 in 224 posts
Given Likes: 3356
05-25-2010, 01:22 PM
[Image: 28740352908900190717.jpg]
The Canadian Wood Council (CWC) is the association responsible for the development and dissemination of technical information on the use of wood products in construction. Ensuring that this information is in tune with technical change and users' needs requires constant vigilance.
The purpose of this fifth edition of the Wood Design Manual is to help the Canadian community design - architects, engineers, specification writers, teachers and students of these disciplines - to design wood structures with efficiency, economy and safety. It brings together, in a comprehensive but concise format, the essential information a designer needs for a wide range of wood structural elements and systems.
The information in the Wood Design Manual is based on the latest information available from the National Building Code of Canada (2005) and from CSA Standard 0-86-01 (2005) Engineering Design in Wood. Every effort has been made to ensure that the date and information in the Manual are accurate and complete. The CWC does not, however, assume any responsability for errors or omissions in the Manual nor for engineering plans or plans prepared from it.
Chapter 1: Introduction
Chapter 2: Bending Members
* General Information
* Sheathing and Decking
* Lumber Joists
* Engineered Joists Beams and Purlins
* Built-up Beams
* Two-way Bending Members
* Cantilevered Beams
Chapter 3: Compression Members
* Stud Walls and Posts Columns
* Built-up Columns
Chapter 4: Tension Members
* Lumber and Glulam
Chapter 5: Combined Loads
* Stud Walls
Chapter 6: Bearing
* Bearing Resistance of Wood
* Bearing Plates
Chapter 7: Fastenings
* Nails and Spikes
* Bolts
* Drift Pins
* Lag Screws
* Timber Rivets
* Shear Plates and Split Rings
* Truss Plates
* Joist Hangers
* Framing Anchors
* Typical Connection Details
Chapter 8: Applications
* Curved Clulam
* Timber Arches
* Pitched-tapered Beams
* Pyramidal, Domed and A-frame Buildings
* Heavy Timber Trusses
* Light Frame Trusses
* Permanent Wood Foundations
* Stressed-sin Panels
* Concrete Formwork
Chapter 9: Shearwalls and Diaphrams
* Diaphragm Design
* Shearwall Design
Chapter 10: Design Fire Safety
* Definitions
* Wood Construction
* Fire-resistance Rating
* Determining Fire-resistance Ratings
* Flame-spread Ratings
* Fire-retardant Treated Wood
Chapter 11: Reference Information
* Section Index
Chapter 12: CSA Commentary(not included)
* Reliability-based Design
* Load Duration
* System modification Factors and Floor Vibration
* Sawn Lumber
* Glulam
* Structural Panels
* Composite Building Components
* Shearwalls and Diaphragms
* Fastenings
* Proprietary Structural Wood Products
[-] The following 30 users Like toa011's post:30 users Like toa011's post
  • NAUTILUS87, vvvv, giga, maad59, kaungthant, Dell_Brett, pezhmankhan, chigozie, novelsus, paliprince, ic1978, levanduy, davegabj, pedronick, Nilupa, bearhunter, avge, sujups, ssi3k, kowheng, yly8, ilgar, oanm2000, super_engineer, archer11, parhyang, Petrit, fer962933, pm81, sivlad
10-18-2010, 06:56 AM (This post was last modified: 07-22-2012, 03:19 AM by kowheng.)
PDF 61.26 MB | RAR 52.58 MB
[-] The following 12 users Like kowheng's post:12 users Like kowheng's post
  • Grunf, rendel_©, ilgar, Gabemzaman, Trishu999, oanm2000, Dell_Brett, cristi, fer962933, sivlad, gulilero, techno
 odiclas
Mexico
User ID: 12601
Threads: 69
Likes: 1,795 in 151 posts
Given Likes: 716
08-26-2014, 05:10 PM
[-] The following 12 users Like odiclas's post:12 users Like odiclas's post
  • milova, knrsa, Dell_Brett, draluka, inge911, sinamaleki, bridgeengineer, carolinandra, spanac, blaze, usman, civilfafa
  [REQUEST] Trial-Use Design Guide for Wood Transmission Structures civilfafa 0 1,540 12-08-2019, 07:54 AM
Last Post: civilfafa
  Wood Handbook- Wood as an Engineering Materials rendel_© 5 4,933 03-08-2017, 05:39 PM
  ANSI/AF&PA NDS-2005: National Design Specification for Wood Construction cmepe 6 6,359 03-27-2016, 03:37 AM
Last Post: RICARDI
  Aluminum Design Manual 2005 Richmond 2 3,504 12-22-2012, 04:56 AM
Last Post: shadabg
  NATIONAL DESIGN SPECIFICATION (NDS) FOR WOOD CONSTRUCTION lucky_b2me 1 3,171 05-17-2010, 12:20 AM
Last Post: Badis
