Civil Engineering Association eBooks Codes, Manual & Handbook Aluminum Design Manual 2005
 Richmond
User ID: 9778
Threads: 9
Likes: 27 in 5 posts
Given Likes: 12
12-13-2011, 09:15 PM (This post was last modified: 12-13-2011, 10:13 PM by 3fan.)
[Image: 53708517969307224325.jpg]
The full design manual can be accessed here.
The following are instructions on how to extract the pdf out of scribd:
1. First of you need to have a pdf printer (Adobe Pdf, PrimoPdf etc.)
2. Open the link above
3. Right click somewhere in a blank region and choose View page source
4. If you are using google chrome, then a new tab should open up with the source code.
5. Ctrl + F command and look for "href"
6. 2nd "href" entry contains a link, click on it
7. Again if you are using google chrome, then a new tab should open up with some source code [less than before]
8. Ctrl + F command and look for "src"
9. 1st "src" entry and maybe the only one contails a link.
10. Copy that link and open it in new chrome tab.
11. If nothing shows up, refresh the tab
12. At this point the whole document should be opened.
13. Click Print on the upper left side
14. Choose your pdf printer and save it somewhere.
15. Wait for some minutes
16. Enjoy!
Let me know if it worked for you. I did not check it on firefox or explorer.
Read the rules! You might be warned by a moderator! Next time you will be warned if uou continue to post transparent links.
[-] The following 2 users Like Richmond's post:2 users Like Richmond's post
  • hcardenas, zrilek
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
12-13-2011, 10:34 PM
Size: 18.3 MB | Format: PDF | Publisher: Alluminum Association Inc | Year: 2005 | pages: 588
[Image: 85807614501326082700.jpg]
[Image: 41580947235154871831.jpg]
The definitive manual for all professionals who work with aluminum in structural applications. This comprehensive, up-to-date edition includes: specifications for aluminum structures - allowable stress design as well as load and resistance factor design, a design guide, materials and material properties, section properties, design aids, and illustrated examples.
Made By CivilEA Post-Generator ver 2.1.2
[-] The following 19 users Like 3fan's post:19 users Like 3fan's post
  • Dell_Brett, Ultra Zone, malc, lednar_ved, odiclas, Jackass, warbeast, kostis, lisine, ssi3k, ibg0203, seriousboy, blackjack, mohamz, frank1972, monter, ykhackhack, harsono, adams
12-22-2012, 04:56 AM
Active Link :
PDF : 17.8 mb
[-] The following 9 users Like shadabg's post:9 users Like shadabg's post
  • ykhackhack, Dell_Brett, knrsa, blaze, stosto6666, adams, ibg0203, Trishu999, chrono146
  ANSI/AF&PA NDS-2005: National Design Specification for Wood Construction cmepe 6 6,360 03-27-2016, 03:37 AM
Last Post: RICARDI
  Wood Design Manual 2005 toa011 2 3,986 08-26-2014, 05:10 PM
Last Post: odiclas
