Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Calculation Notes & Analysis Files Analysis of a Building 4 floors in Etabs
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
12-11-2009, 05:44 AM (This post was last modified: 12-11-2009, 05:44 AM by Veggeta.)
Analysis of a building of metallic structure of 4 floors(flats), realized in Etabs...
[Image: 07282536627184386885.jpg]
[-] The following 16 users Like Veggeta's post:16 users Like Veggeta's post
  â€¢ Grunf, oanm2000, vinnunsam, vedranius, jaks, ruaumoko, relu59, kerenski_t, kvsambath, zeemas, Alexander88, rey_zone, kami, gatob, Nilupa, youceftli
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,197 in 2,356 posts
Given Likes: 4260
12-11-2009, 06:30 AM
can you explain more from this model?
- type of frames
- codes of design
- place
- type of other elements
this look a good model...
[-] The following 2 users Like Administrator 's post:2 users Like Administrator 's post
  â€¢ Grunf, dalberto
 robertsas
Indonesia
User ID: 655
Threads: 155
Likes: 5,665 in 416 posts
Given Likes: 3149
12-11-2009, 07:20 AM
Dear Veggeta,
I run this model without change anything, it give :
* * * W A R N I N G * * *
ZERO STIFFNESS FOUND DURING SOLUTION FOR DOF UX OF JOINT 872
LOCATED AT X = 12.500000, Y = 1.500000, Z = 5.650000,
STIFFNESS MATRIX DIAGONAL VALUE SET TO 1.00E-10
THE STRUCTURE IS UNSTABLE OR ILL-CONDITIONED !!
CHECK THE STRUCTURE CAREFULLY FOR:
- INADEQUATE SUPPORT CONDITIONS, OR
- ONE OR MORE INTERNAL MECHANISMS, OR
- ZERO OR NEGATIVE STIFFNESS PROPERTIES, OR
- EXTREMELY LARGE STIFFNESS PROPERTIES, OR
- BUCKLING UNDER P-DELTA LOADS (IF ANY), OR
- AN EIGEN SHIFT (IF ANY) ONTO A NATURAL FREQUENCY
I fixed it because some of stair beams are not conected to the bordes (LOCATED AT X = 12.500000, Y = 1.500000, Z = 5.650000)
May I ask you what kind of material Durock? Can you explained what is that material..
because you run with UBC respons spectrum with Scale Factor = 0,3...
regards,
robertsasmita
[-] The following 2 users Like robertsas's post:2 users Like robertsas's post
  â€¢ Grunf, oanm2000
 vinnunsam
User ID: 3932
Threads: 34
Likes: 1,281 in 116 posts
Given Likes: 457
12-11-2009, 07:22 PM
Dear Veggeta,
Have you prepared a DBR (Design Basis Report) for this model. If you have completed, can you upload it.
[-] The following 1 user Likes vinnunsam's post:1 user Likes vinnunsam's post
  â€¢ zayobayo1
 Veggeta
Guatemala
User ID: 114
Threads: 98
Given Likes: 403
12-11-2009, 11:40 PM
Dear Robertsas,
I will check the very prompt model, it is possible that I have been wrong of file ... what happens is that I am out for labour motives and not have access to my files these days..
If I have it, but in Spanish, I am going to summarize it and am going to hang it...
Sorry for the caused problems...
Sorry bad englis...
Regards...
[-] The following 5 users Like Veggeta's post:5 users Like Veggeta's post
  â€¢ robertsas, vinnunsam, Ultra Zone, Grunf, jaks
 Nilupa
Sri Lanka
User ID: 11056
Threads: 32
Likes: 95 in 26 posts
Given Likes: 4796
12-22-2009, 03:09 PM
don't you have sap analysis file..?
[-] The following 1 user Likes Nilupa's post:1 user Likes Nilupa's post
  â€¢ ruwan75
 tase
User ID: 4066
Likes: 2 in 1 posts
Given Likes: 2
01-28-2010, 06:54 PM
hello!
If you still watch this thread can you explain me what was to purpose of modelling the exterior walls? The horizontal shear force will load these walls while the frames will be unloaded.
[-] The following 2 users Like tase's post:2 users Like tase's post
  â€¢ belkhedim, sedo88
  Analysis and Design example of Two Storey Building using Etabs erimajus 4 19,143 04-23-2011, 06:23 AM
Last Post: David90
  ANALYSIS APARTMENTS BUILDING IN ETABS Veggeta 2 14,008 03-31-2011, 01:12 AM
Last Post: vish5610
