Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Staircase Analysis and Design Spreadsheet
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1405
05-11-2018, 09:16 PM (This post was last modified: 05-11-2018, 09:16 PM by rami1976.)
[Image: 11819317955664076806.png]
[Image: 21690533727803328059.png]
[Image: 21489326317727803684.png]
Staircases provide means of movement from one floor to another in a structure. Staircases consist of a number of steps with landings at suitable intervals to provide comfort and safety for the users.
Types of Stairs
For purpose of design, stairs are classified into two types; transversely, and longitudinally supported.
a- Transversely supported (transverse to the direction of movement):
Transversely supported stairs include:
ยง Simply supported steps supported by two walls or beams or a combination of both.
ยง Steps cantilevering from a wall or a beam.
ยง Stairs cantilevering from a central spine beam.
b- Longitudinally supported (in the direction of movement):
These stairs span between supports at the top and bottom of a flight and unsupported at the sides. Longitudinally supported stairs may be supported in any of the following manners:
a. Beams or walls at the outside edges of the landings.
b. Internal beams at the ends of the flight in addition to beams or walls at the outside edges of
the landings.
c. Landings which are supported by beams or walls running in the longitudinal direction.
d. A combination of (a) or (b), and ©.
e. Stairs with quarter landings associated with open-well stairs.
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
[-] The following 38 users Like rami1976's post:38 users Like rami1976's post
  โ€ข axcel, carolinandra, Batman07, milova, caifan, usman, ali akbar, Andrew seah, blaze, zrilek, sabooryan, dizz, Dell_Brett, RajaK, calmchi, karthikeyans3d, oanm2000, K.Lee, albani, odiclas, vvvv, tuanpecc1, febo927, PinkPant, simanta, pcworks200, malc, gafi, monter, paulocs, scorpion07, emmi, zego2000, cristi, er.shyams, jaks, spat, mary
 jayborre
Junior Member
Philippine
User ID: 243
Threads: 6
Likes: 49 in 10 posts
Given Likes: 546
06-21-2023, 03:44 PM
Requesting to re-upload the file. Kindly provide a working link. Thanks
  โ€ข
 odiclas
Mexico
User ID: 12601
Threads: 69
Likes: 1,795 in 151 posts
Given Likes: 716
06-22-2023, 01:11 AM
pls ... re upload
thank u
  โ€ข
 odiclas
Mexico
User ID: 12601
Threads: 69
Given Likes: 716
06-22-2023, 01:20 AM (This post was last modified: 06-25-2023, 11:17 PM by Dell_Brett.)
Hi, here can you download the spreadsheet...
[-] The following 8 users Like odiclas's post:8 users Like odiclas's post
  โ€ข zrilek, jayborre, tuanpecc1, melekeen, babakfeyzi, Dell_Brett, blaze, cace-01
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
06-25-2023, 11:19 PM
[-] The following 13 users Like Dell_Brett's post:13 users Like Dell_Brett's post
  โ€ข ranger, zrilek, rami1976, Administrator , PinkPant, mary, cace-01, bao2004, Kurucz, amindoxiti, Umer.Aleem, dinu69in, sodapas
  Spreadsheet for Design of Elastomeric Bearings for Bridges ali akbar 1 9,368 11-06-2020, 02:00 PM
Last Post: ali akbar
  38 Foundation Design spreadsheet based on ACI 318-08 portal61 2 12,926 01-17-2014, 11:42 PM
Last Post: ykhackhack
  online spreadsheet for DESIGN OF ISOLATION SYSTEM FOR BRIDGES david-smith 3 9,736 11-05-2012, 03:58 PM
Last Post: 3fan
  Band Drain Design Spreadsheet jacs127 1 8,689 05-03-2012, 01:00 PM
Last Post: shadabg
  Elastomer Bearing Design Spreadsheet Dell_Brett 0 7,181 09-09-2011, 05:07 AM
Last Post: Dell_Brett
