Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Concrete: Concrete Short Column Analysis and Design
Threads: 1,118
06-30-2009, 03:42 PM (This post was last modified: 02-27-2015, 04:38 PM by usman.)
ShortCol
Calculates bending moment/axial force interaction diagram for rectangular or circular reinforced concrete column with typical or irregular rebar layout. Now calculates crack width under working stresses. Confirms ACI 318, AASHTO and AS3600 design codes.
ShortCol - investigation of reinforced concrete column section
ShortCol computes ultimate strength of reinforced concrete column subjected to combined axial force and bending moment. Ultimate strength is found from strain compatibility analysis assuming equivalent rectangular concrete stress distribution. In addition, ShortCol calculates transformed properties of fully cracked reinforced concrete section at ultimate limit state and calculates crack width at service limit states.
Another features:
•Shortcol analyses rectangular or circular shape concrete sections
•Rebar wizard quickly generates various typical and irregular bar layouts
•Crack width is calculated in accordance with ACI/AASHTO, British Standards, Eurocode 2 and AS3600
•Column design conforms ACI 318, AASHTO, AS3600 codes
•SI and US units
ShortCol limitations:
•Does not consider column slenderness and second order effects
•Uses only unconfined concrete properties
•Accepts only bonded to concrete reiforcing steel
The file includes the original (shareware) version and a little bit changed version.
screenshots:
[Image: shortr.th.jpg]
Links changed and alive.
[-] The following 23 users Like BennyP's post:23 users Like BennyP's post
  • Dell_Brett, Dell_Brett, kowheng, kowheng, ruaumoko, ruaumoko, paulocs, paulocs, cristi, cristi, rendel_©, rendel_©, Nedian, Nedian, Ultra Zone, rkce, rezart, Quantumm, robertsas, SCREAM7890, K.Lee, tuanpecc1, ashcivilea
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
12-01-2010, 10:09 PM
[Image: 88666899229157589379.jpg]
Mirror
430KB XLS
[-] The following 12 users Like usman's post:12 users Like usman's post
  • Dell_Brett, ISTRAKTURA, kowheng, rezart, Quantumm, robertsas, duyhiep83, malc, zainseiya, dinu69in, SCREAM7890, odiclas
 scorpion07
Albania
User ID: 550
Threads: 3
Likes: 1,366 in 104 posts
Given Likes: 277
11-12-2016, 12:21 AM
New links
[-] The following 18 users Like scorpion07's post:18 users Like scorpion07's post
  • versiondemo, mgdario, Albert, Dell_Brett, rami1976, Jackass, blaze, PinkPant, Andrew seah, oanm2000, karthikeyans3d, odiclas, K.Lee, rendel_©, Umer.Aleem, zrilek, spat, sodapas
Threads: 274
Likes: 12,075 in 1,233 posts
09-16-2020, 06:59 AM
ShortCol 2002
[Image: 75595598529395187020.jpg]
Major update! Design for shear and torsion added + ACI 318-19 included.
[-] The following 22 users Like pezhmankhan's post:22 users Like pezhmankhan's post
  • blaze, malc, KMABD, mgdario, promo8, oanm2000, cace-01, simanta, zrilek, PinkPant, chandra1234567, pontiac, caifan, Dell_Brett, kowheng, gulilero, tuanpecc1, mowafi3m, jacky899, cristi, ashcivilea, vvvv
 alikhs2002
Junior Member
User ID: 33818
Likes: 9 in 7 posts
Given Likes: 14
11-03-2021, 01:49 PM
Can anyone reupload please?
[-] The following 1 user Likes alikhs2002's post:1 user Likes alikhs2002's post
  • albani
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
11-07-2021, 04:31 AM
concrete solution advocate
[-] The following 12 users Like concreteok's post:12 users Like concreteok's post
  • Dell_Brett, blaze, karthikeyans3d, rami1976, subin91, Umer.Aleem, albani, Wijono, milova, alikhs2002, sodapas, jayborre
  Concrete: RC Spreadsheets V4 (RCCV4) The Concrete Centre Gabemzaman 11 38,651 02-06-2023, 01:56 PM
Last Post: chukwuma
  Concrete: Spreadsheets to British and Eurocode V4a The Concrete Centre 3fan 5 18,314 08-13-2021, 08:32 AM
Last Post: concreteok
  Spread Footing Analysis and Concrete Pedestal Design usman 1 11,435 06-29-2017, 03:41 PM
Last Post: ALMF
  Concrete: Spreadsheets for Concrete Design to BS 8110 and EC2 rohailiyaz 4 21,216 04-12-2014, 06:52 PM
Last Post: darebert1000
  Concrete: Rectangular Columns with Uniaxial Bending Analysis and Design by JEC robertsas 4 12,459 04-03-2014, 01:57 PM
Last Post: arshiakh
  Concrete Short Column Analysis and Design - EC BennyP 2 11,320 08-24-2013, 11:23 AM
Last Post: pezhmankhan
  Concrete: Concrete Design Spreadsheets RedHorse 3 16,056 04-21-2013, 04:22 AM
