Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Analysis: GoBeam
Analysis: GoBeam
Threads: 274
Likes: 12,075 in 1,233 posts
03-07-2015, 07:38 AM
GoBeam 143
[-] The following 12 users Like pezhmankhan's post:12 users Like pezhmankhan's post
  â€¢ PinkPant, blaze, jcbv, bridgeengineer, oanm2000, chenamoy, Williams, gulilero, ykhackhack, scorpion07, harsono, nibbi
Threads: 274
03-03-2017, 05:25 AM (This post was last modified: 03-03-2017, 01:52 PM by 3fan. Edit Reason: Additional info )
GoBeam 2015.1
The easiest and most straight forward continuous beam analysis program available. Features static and moving loads, support settlements, non-linear analysys of beam on elastic foundation and influence lines analysis. It allows elastic and column support conditions, hinges and variable beam stiffness.
[Image: homepage.png]
[-] The following 13 users Like pezhmankhan's post:13 users Like pezhmankhan's post
  â€¢ malc, blaze, hmwere, Andrew seah, Dell_Brett, 3fan, oanm2000, promo8, yutt, mowafi3m, vvvv, karthikeyans3d, Rodmo376
Threads: 274
09-14-2020, 10:43 AM
GoBeam 1912
Updated moving load analysis analysis allows to output results for multiple trucks in a single run (great for bridge load rating!) and to combine static loads with moving loads.
  â€¢ temp1366, Andrew seah, jonygut, malc, kowheng, PinkPant, zrilek, oanm2000, structural, Dell_Brett, jacky899, monter, legarleon
 toddyi
Junior Member
User ID: 396
Threads: 4
Likes: 19 in 6 posts
Given Likes: 40
#14
02-24-2021, 08:57 AM
LINK does not work
  â€¢
Pages (2): « Previous 1 2
