Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Calculation Notes & Analysis Files Design of 5,000 Gal. Elevated Tank ( conical bottom ) using Staad Pro.
 ranger
Philippine
User ID: 25614
Threads: 180
Likes: 1,078 in 204 posts
Given Likes: 980
01-21-2011, 12:12 PM
[Image: 75774338705195250835.jpg]
[-] The following 15 users Like ranger's post:15 users Like ranger's post
  â€¢ kowheng, oanm2000, blaze, gatob, duazo2009, usman, Quantumm, lednar_ved, mrgoodboydatdat, JPx2, bosstrisha, Nilupa, addy85, parwez007, bigone
 ASEC
United States
User ID: 13344
Threads: 11
Likes: 397 in 113 posts
Given Likes: 298
03-12-2011, 01:29 AM (This post was last modified: 03-12-2011, 11:32 AM by ASEC.)
Just a couple of observations that you need to correct with your model.
1.You have duplicate nodes in the model, if not corrected you will get erroneous load transfer
2. Improperly connected plates, same consequence as item 1
3. Weight of Water has not been considered in the primary load case dead load
4. Should also be checked with Wind Load
5. Worst condition for Earthquake and Wind Loads should be checked when tank is full and when tank is empty.
6. Rw value should conform to the code you are using UBC or ASCE
7. You have specifiy "tension member" for some members, tension or compression member is a non-linear member you should use them with primary load case and not load combination. Hence, use repeat load command . refer to staad manual for further info.
8. You execute two designs for steel members using ASD and LRFD but using factored load combinations which is not applicable to ASD. You should create two load envelopes one for service load for ASD and another load envelop for LRFD.
9. Better use p-dleta analysis to consider secondary moments.
Just correct the above and you are in the right direction.
[-] The following 14 users Like ASEC's post:14 users Like ASEC's post
  â€¢ gelbert, Grunf, zbizafar, Dell_Brett, dquan373, ranger, mrgoodboydatdat, Mr_popo, addy85, parwez007, jaks, bigone, henrycv, mannyzuniega
  Oil Storage Tank Design Calculation as per API 650 duazo2009 5 19,861 02-09-2019, 08:02 AM
  Design of 5,000 Gal. Elevated Tank using Staad Pro. ranger 4 16,316 12-18-2012, 05:37 AM
Last Post: oram
