Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM - User's Guide to ASTM Specification C94 on Ready-Mixed Concrete
 ibg0203
China
User ID: 1557
Threads: 280
Likes: 6,208 in 686 posts
Given Likes: 1411
09-16-2010, 05:56 PM (This post was last modified: 12-29-2011, 07:14 PM by usman.)
on
[Image: 17924309670173195705.jpg]
User's Guide to ASTM Specification C94 on Ready-Mixed Concrete (ASTM Manual) (Astm Manual Series, Mnl 49)
By D. Gene Daniel; Colin L. Lobo
Publisher: ASTM International
Number Of Pages: 130
Publication Date: 2005-01-01
ISBN-10 / ASIN: 0803133634
ISBN-13 / EAN: 9780803133631
Product Description:
ASTM C 94 covers the complex subject of ready-mixed concrete. This manual, co-published by ASTM International and the National Ready-Mixed Concrete Association, provides a complete and detailed explanation of C 94's uses and applications. It cuts through the broad language of the standard by using straightforward explanations and examples. Twenty comprehensive chapters plus an overview cover: • Background of ASTM C 94/C 94M • Scope • Referenced Documents • Basis of Purchase • Ordering Information • Materials • Tolerances in Slump • Air-Entrained Concrete • Measuring Materials • Batching Plant • Mixers and Agitators • Mixing and Delivery • Uses of Nonagitating Equipment • Batch Ticket Information • Plant Inspection • Practices, Test Methods, and Reporting • Sampling and Testing Fresh Concrete • Failure to Meet Strength Requirements • Keywords • Annex of Mandatory Information
Contents
Preface
Introduction
Chapter 1--Scope
Chapter 2--Referenced Documents
Chapter 3--Basis of Purchase
Chapter 4reOrdering Information
Chapter 5--Materials
Chapter 6--Tolerances in Slump
Chapter 7--Air-Entrained Concrete
Chapter 8--Measuring Materials
Chapter 9--Batching Plant
Chapter 10mMixers and Agitators
Chapter 11 ~Mixing and Delivery
Chapter 12--Use of Nonagitating Equipment
Chapter 13~Batch Ticket Information
Chapter 14--Plant Inspection
Chapter 15--Practices, Test Methods, and Reporting
Chapter 16~Sampling and Testing Fresh Concrete
Chapter 17~Strength
Chapter 18--Failure to Meet Strength Requirements
Chapter 19~Keywords
Chapter 20~Annex (Mandatory Information)
References
Appendix--ASTM C 94-35
password for ifile link only, other links none
[-] The following 6 users Like ibg0203's post:6 users Like ibg0203's post
  • Grunf, kowheng, Dell_Brett, datagap, utan, shaqee
12-09-2010, 05:29 PM (This post was last modified: 08-05-2012, 07:27 AM by kowheng.)
Bookmark PDF|RAR 5.19|4.94 MB
[-] The following 11 users Like kowheng's post:11 users Like kowheng's post
  • usman, blaze, zrilek, utan, Dell_Brett, roaming79, civiea_civiea, pram, visu, Jarty, portal61
  [CivilEA Exclusive] ASTM C635 C635M: Standard Specification for Manufacture, Performance, and Testing of poolmand 0 263 06-17-2026, 06:05 AM
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,970 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,312 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,095 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,142 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,359 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,421 11-01-2023, 07:18 AM
