Civil Engineering Association eBooks Codes, Manual & Handbook ASTM [CivilEA Exclusive] ASTM C635 C635M: Standard Specification for Manufacture, Performance, and Testing of
Threads: 769
Likes: 8,311 in 1,373 posts
Given Likes: 94
06-17-2026, 06:05 AM (This post was last modified: 06-17-2026, 06:07 AM by poolmand.)
ASTM C635/C635M-22: Standard Specification for Manufacture, Performance, and Testing of Metal Suspension Systems for Acoustical Tile and Lay-in Panel Ceilings
| Size: 980 KB| Format: PDF| Quality: Scanner| Year: 2022 | ISBN: 10.1520/C0635_C0635M-22
[Image: do.php?img=39]
This specification covers metal ceiling suspension systems used primarily to support acoustical tile or acoustical lay-in panels. Some suspension systems incorporate locking assembly details that enhance performance by providing some continuity or load transfer capability between adjacent sections of the ceiling grid. The structural classification or grade of ceiling suspension systems shall be determined by the capability of main runners or nailing bars to support a uniformly distributed load. These classifications shall be: light-duty systems; intermediate-duty systems; and heavy-duty systems. The structural classification of ceiling suspension systems shall be based on the load-carrying capacity of the main runners of the structural network. Suspension system structural members shall conform to the following tolerance requirements: metal thickness; straightness; length; overall cross-section dimensions; and section squareness.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
  â€¢ zrilek, lisine, Dell_Brett, babakfeyzi, subin91
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,172 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,497 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,272 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,333 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,547 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,627 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 3,163 10-28-2023, 06:32 AM
