Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Problem installing Tekla 16.0
 faros3000
Senior Member
User ID: 61
Threads: 24
Likes: 1,265 in 175 posts
Given Likes: 1793
03-05-2010, 04:44 AM
I´m having troubles during installation:
I installed Tekla in the default diretory:
C:\Program Files\Tekla Structures\16.0\nt\bin
but when I try to apply the crack on teklastructures.exe, the following message appears:
[Image: 85567396974210638971.jpg]
Any help plz?
Information is not knowledge.
Albert Einstein
 alisafei
Member
User ID: 4833
Threads: 7
Likes: 413 in 44 posts
Given Likes: 7
03-05-2010, 05:09 AM
your installation file version and medicine version is different. i guess your installation file is newer than your medicine. try to download installation file and medicine together (both links are in same post).
[-] The following 1 user Likes alisafei's post:1 user Likes alisafei's post
  • faros3000
 faros3000
Senior Member
User ID: 61
Threads: 24
Given Likes: 1793
03-05-2010, 07:27 AM
Thanks Alisafei, I was effectively mixing version 64-bits with medicine for 32-bits and now the problem is solved.
One more question for the experienced users of Tekla. Comparing my "about" window:
[Image: 56217389221167901214.jpg]
with the one posted by BennyP in the Tekla 16.0 thread:
[Image: 20651343440517744816.jpg]
It looks that I am missing the module for analysis and design. How can I activate it? Any idea/ssugestion?
Thanks un advance,
Albert Einstein
 yakwetu
User ID: 1947
Threads: 57
Likes: 1,240 in 130 posts
Given Likes: 154
03-05-2010, 07:51 AM (This post was last modified: 03-05-2010, 07:55 AM by yakwetu.)
It has to do with data your had inputed on the Login- in page, when TEKLA starts where you input your desired ENVIRONMENT, ROLE and LICENSE!
In BENNYP's case he chose the following
ROLE: ALL
LICENSE: FULL
[-] The following 1 user Likes yakwetu's post:1 user Likes yakwetu's post
  • faros3000
 archiphil
User ID: 20099
Likes: 0 in 0 posts
Given Likes: 4
04-23-2010, 07:46 PM
(03-05-2010, 04:44 AM)faros3000 Wrote: I´m having troubles during installation:
Any help plz?
hi faros3000...i got same problem with you on applying the patch on tekla v16..how did you solve the problem..im using 32bit version..can u send me the patch you use...tnx
 faros3000
Senior Member
User ID: 61
Threads: 24
Given Likes: 1793
05-01-2010, 01:47 AM
(04-23-2010, 07:46 PM)archiphil Wrote: hi faros3000...i got same problem with you on applying the patch on tekla v16..how did you solve the problem..im using 32bit version..can u send me the patch you use...tnx
My problem was that I installed Tekla v16 64-bits, and was applying the patch for 32-bits (that´s the reason why the size of the files didn´t match). After that I downloaded the patch for 64-bits and the problem was solved.
If you´re experiencing the same problem, but your using a 32-bits OS, then the reason has to be you are trying to apply the patch for 64-bits. Make sure you are downloading/installing Tekla v16 32-bits as well as downloading/installing the patch for 32-bits.
Both the instalation files and the patch I used were the ones posted here in CivilEA.
Hope this helps!
Albert Einstein
[-] The following 1 user Likes faros3000's post:1 user Likes faros3000's post
  • archiphil
  Sofistik installing and crack aMoUr 2 8,758 09-02-2010, 09:47 AM
Last Post: PanosP
