Civil Engineering Association Software Software Product Bentley Products STAAD.foundation V8i SELECTseries 2 (Release 5.1)
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,982 in 4,091 posts
Given Likes: 612
03-26-2010, 08:57 AM
STAAD.foundation is standalone software with more than 50 different design modules and 5 different international codes. It is cost-saving downstream application that also enables engineers to analyze and design the underlying foundation for the structure they created in STAAD.Pro. STAAD.foundation can automatically absorb the geometry, loads and results from a STAAD.Pro model and accurately design isolated or combined footings, true mat foundations and even perform pile cap arrangements. Data from other superstructure analysis design packages can be imported to STAAD.foundation through Microsoft Excel.
The previous 1000 days trial works.
[Image: 85988164675864988875.gif]
[-] The following 20 users Like BennyP's post:20 users Like BennyP's post
  • hapsea, vvvv, Dell_Brett, Albert, Adam Smith, gacella, kaungthant, sasan51, sonidero, oanm2000, civilteam, haze, tolesa54, rendel_©, d.sivasekhar, Finna, cazoneño, ambrish, zrilek, ranger
 kardels
User ID: 2758
Threads: 40
Likes: 1,494 in 84 posts
Given Likes: 311
04-21-2010, 05:42 AM (This post was last modified: 06-04-2012, 02:34 AM by usman.)
STAAD.foundation V8i SELECT series 2 (Release 5.1)
STAAD.foundation V8i SELECT series 2 (Release 5.1) is finally released. This version is a major update on version 5.0 and specially focused on plant foundations.
Plant foundation mode has been revisited and enhanced to align the work flow with the practical needs of practicing engineers. Detailed drawings are updated with customizable drawing notes
"Bearing capacity factor table" is introduced to apply load combination dependent bearing capacity. For instance most code allows 33% increase of bearing capacity for temporary load cases like wind load or seismic load. This table is mandatory for some codes like Canadian code where soil pressure check is done for both un-factored and factored load combinations. The same table can be used to factor bearing capacity for factored load combination.
"Ribbed Beam" foundation is added in toolkit mode. This is a special type of foundation where a beam is connected between two columns of a combined footing and is a popular foundation type in India as it saves concrete.
Load combination generation table is added for all supported country codes.
For a detailed list of new enhancements and features please review What's New document
screenshot:
[Image: 18508415834710210376.jpg]
[Image: 33109893199454296817.jpg]
link 1: Bentley IEG License Service 02.00.16.00 installer (installed 1st)
link 2: STAAD.foundation V8i 05.01.00.00 installer
Mirror/Alternate links:
trial version
[-] The following 15 users Like kardels's post:15 users Like kardels's post
  • abudabeeja, raad kamil, haze, jjmtz, sasan73, julioreptil, Raktim, aami32, mohcivil, panchotevi, narendra, sudershan, vaidyanathan, zrilek, adamsawi
  STAAD.Pro V8i SELECTseries 5, build 20.07.10.64 coxxxyboy 9 27,004 07-07-2023, 02:35 AM
Last Post: Arigato
  STAAD Foundation Advanced x86 V09.06.01.074 RajaK 0 6,203 10-04-2021, 05:59 AM
Last Post: RajaK
  STAAD Foundation Advanced CONNECT Edition 08.04.00.21 kirankumarklk 1 5,328 06-27-2018, 08:46 AM
Last Post: er.shyams
  STAAD Foundation Advanced CONNECT Edition 08.03.00.20 BennyP 0 4,686 02-11-2018, 05:31 PM
  Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.70 RajaK 5 17,272 12-31-2017, 06:07 AM
Last Post: reagan_liu
  Bentley Staad Foundation Advanced CONNECT Edition RajaK 1 7,435 01-16-2016, 10:51 AM
Last Post: Dell_Brett
  Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.33 er.shyams 6 21,520 01-15-2016, 08:39 AM
Last Post: RajaK
