Civil Engineering Association eBooks Structural Books Steel Design Of Steel Structures I & II - by Prof. S.R.Satish Kumar & Prof.A.R.Santha Kumar
 vinnunsam
User ID: 3932
Threads: 36
Likes: 1,281 in 116 posts
Given Likes: 457
Points:9,083 EP
11-15-2009, 06:18 PM (This post was last modified: 11-10-2012, 07:42 AM by mybest.)
Design Of Steel Structures I - By Prof. S.R.Satish Kumar & Prof.A.R.Santha Kumar
[Image: 93403135974307029921.jpg]
Steel is by far the most useful material for building structures with strength of approximately ten times that of concrete, steel is the ideal material for modern construction. Due to its large strength to weight ratio, steel structures tend to be more economical than concrete structures for tall buildings and large span buildings and bridges. Steel structures can be constructed very fast and this enables the structure to be used early thereby leading to overall economy. Steel structures are ductile and robust and can withstand severe loadings such as earthquakes. Steel structures can be easily repaired and retrofitted to carry higher loads. Steel is also a very eco-friendly material and steel structures can be easily dismantled and sold as scrap. Thus the lifecycle cost of steel structures, which includes the cost of construction, maintenance, repair and dismantling, can be less than that for concrete structures. Since steel is produced in the factory under better quality control, steel structures have higher reliability and safety.
[-] The following 35 users Like vinnunsam's post:35 users Like vinnunsam's post
  • seriousboy, Dell_Brett, coxxxyboy, kowheng, robertsas, mowafi, u4406014, jcoronellr, levanduy, marcel1983, raslanuf, narendra, lucky_b2me, boycv, sangen, civilteam, YaqubMughal, jagadishnr_nr, cristi, vvvv, salahcivil, ilgar, super_engineer, chenamoy, tarasu, sodapas, handresy, ravisbassi, Quantumm, i_kabir, rezart, Nilupa, rhino13, ruaumoko, tuanpecc1
 vinnunsam
User ID: 3932
Threads: 36
Given Likes: 457
Points:9,083 EP
11-15-2009, 06:25 PM (This post was last modified: 12-13-2011, 12:00 AM by usman.)
Design Of Steel Structures II - By Prof. S.R.Satish Kumar & Prof.A.R.Santha Kumar
[Image: 01364808901426570681.jpg]
I. MOMENT CONNECTIONS
II. INDUSTRIAL BUILDINGS
III. MULTI-STOREYED BUILDINGS
IV. BRIDGES
V. TANKS
VI. TOWERS
[-] The following 18 users Like vinnunsam's post:18 users Like vinnunsam's post
  • essam2109, Dell_Brett, coxxxyboy, kowheng, jferrer, mowafi, u4406014, boycv, sangen, robertsas, levanduy, chigozie, ilgar, hernansgz, deadlord, oanm2000, rezart, Nilupa
 vinnunsam
User ID: 3932
Threads: 36
Given Likes: 457
Points:9,083 EP
11-16-2009, 02:02 PM
Dear fun113113,
The reference to the version of the code that is been used in this notes is actually mentioned at the end of each chapter under the heading "Reference".
Please after downloading you can see the version of the codes that are referred by the author to explain the theory and the principle behind the design of steel structures I.
Example: For Chapter One, the author has referred the following references,
1.9 References
1. IS 800-2005 (Draft) ‘Code of practice for general construction in steel’ , Bureau of
Indian Standards, New Delhi.
2. IS 801-1975 Code of practice for use of cold-formed light gauge steel structural
members in general building construction (first revision), Bureau of Indian Standards,
New Delhi.
3. IS 1024-1999 Code of practice for use of welding in bridges and structures subject
to dynamic loading (second revision), Bureau of Indian Standards, New Delhi.
4. IS 2062-1999 Specification of steel for general structural purposes (fifth revision),
5. IS 8500-1991 Specifications for structural steel-micro alloyed (medium and high
strength qualities), Bureau of Indian Standards, New Delhi.
6. IS 9172-1979 Recommended design practice for corrosion protection of steel
structures, Bureau of Indian Standards, New Delhi.
7. IS 12778-1989 Hot rolled steel parallel flange beam and column sections-
Dimensions, Bureau of Indian Standards, New Delhi.
8. IS 1477-2000 (Part1) Code of practice for painting of ferrous metals in buildings:
Pre-treatment (second revision), Bureau of Indian Standards, New Delhi.
9. IS 1477-1971 (Part2) Code of practice for painting of ferrous metals in buildings:
painting (first revision), Bureau of Indian Standards, New Delhi.
10. SP7-2003 Part 4: Fire and life safety, Bureau of Indian Standards, New Delhi.
11. SP: 6(1) - 1972 ‘Handbook for Structural Engineers’ Rolled steel sections. Bureau
[-] The following 7 users Like vinnunsam's post:7 users Like vinnunsam's post
  • Dell_Brett, kowheng, Ultra Zone, levanduy, lucky_b2me, sodapas, rendel_©
 deviationz
User ID: 2031
Threads: 51
Likes: 546 in 107 posts
Given Likes: 72
Points:6,533 EP
03-31-2010, 05:45 PM (This post was last modified: 03-31-2010, 06:08 PM by BennyP.)
You can access them here
[-] The following 18 users Like deviationz's post:18 users Like deviationz's post
  • engr1900, Grunf, simanta, robertsas, isurya, hsccindia, levanduy, u4406014, civilteam, davegabj, hernansgz, oanm2000, Dell_Brett, ilgar, DamaD, rezart, Nilupa, ting tsai huang
Likes: 33,527 in 2,936 posts
Points:158,166 EP
04-01-2010, 05:18 PM (This post was last modified: 07-06-2012, 09:30 AM by kowheng.)
[-] The following 29 users Like kowheng's post:29 users Like kowheng's post
  • Grunf, oanm2000, u4406014, engr1900, user108, imatoric, salahcivil, hernansgz, tarasu, andi jackson, yphani222, jcbv, jcoronellr, Dell_Brett, rkce, ravisbassi, blaze, ilgar, Adam Smith, cowboy, rezart, i_kabir, Administrator , cesar3226, skvskv, Nilupa, jjinravi, ting tsai huang, shadabg
Points:136,043 EP
06-04-2010, 06:48 AM
Mirror link:
[-] The following 13 users Like Grunf's post:13 users Like Grunf's post
  • oanm2000, jcbv, Raktim, tarasu, adi04, mp1_1, atulkrengineer, rendel_©, ruaumoko, engrasad, Administrator , rezart, ranger
 adshrt
User ID: 8297
Threads: 36
Likes: 1,203 in 114 posts
Given Likes: 364
Points:6,502 EP
09-03-2010, 07:24 AM
[-] The following 13 users Like adshrt's post:13 users Like adshrt's post
  • jcoronellr, oanm2000, Dell_Brett, cristi, clondonom, alisial, Quantumm, rezart, cesar3226, Nilupa, ruaumoko, skvskv, hignacio43
 rezart
User ID: 25808
Threads: 77
Likes: 2,748 in 178 posts
Given Likes: 5842
Points:11,290 EP
12-07-2010, 08:18 PM
Design of Steel Structures (Full Lectures)
Prof. A. R. Shantha Kumar
Prof. S. R. Satish Kumar
Introduction (2 lectures)
Properties of Structural Steel, I. S. Rolled Sections, I. S. Specifications
II. Design Approach (2 lectures)
Factor of Safety, Permissible and Working Stresses, Elastic Method, Plastic
Method, Introduction to Limit States of Design
III. Connections (5 lectures)
Type of Connections, Riveted, Bolted and Welded Connections, Strength, Efficiency
and Design of Joints, Modes of Failure of a Riveted Joint, Advantages and
Disadvantages of Welded Joints, Design of Fillet and Butt Welds, Design of
Eccentric Connections
IV. Tension Members (8 lectures)
Net Sectional Area, Permissible Stress, Design of Axially Loaded Tension Member,
Design of Member Subjected to Axial Tension and Bending
V. Compression Members (9 lectures)
Modes of Failure of a Column, Buckling Failure: Euler’s Theory, Effective Length,
Slenderness Ratio, Design Formula: I.S. Code Formula, Design of Compression
Members, Design of Built-Up Compression Members: Laced and Battened Columns
VI. Beams (8 lectures)
Design Procedure, Built-Up Sections, Plate Thickness, Web Crippling, Web
Buckling, Connections and Curtailment of Flange Plates
VII. Beam Column (3 lectures)
Eccentricity of Load, Interaction Formulae, Design Procedure, Eccentrically Loa
Base Plates
VIII. Column Base (3 lectures)
Slab Base, Gusseted Base, Grillage Foundation
1) Simple, Semi-rigid and Rigid Connections.
2) Connection Configurations
3) Angle Cleat Connections
4) End-plate Connections
5) Semi-rigid Connections
6) Moment-rotation Characteristics
1) Structural Configurations
2) Functional and Serviceability Requirements
3) Industrial Floors
4) Roof Systems
5) Plastic Analysis and Design of Portal Frames
6) Crane Gantry Girders
7) Design for Wind Actions
8) Design for Earthquake Actions
2) Steel-Concrete Comosite Floor Systems
3) Loading
4) Analysis for Gravity Loads
5) Lateral Load Resisting Systems
6) Analysis for Lateral Loads
7) Dual Systems
8) Advanced Structural Forms
IV. BRIDGES
1) Classification and Types of bridges
2) Load and Load Combination for highway Bridges
V. TANKS
VI. TOWERS
3) Load and Load Combination for Railway Bridges
4) Wind and Earthquake Effects
5) Design of a Typical Truss Bridge
6) Bearings and Supporting Elements
1) Introduction- Types of Tanks
3) Design Aspects of Cylindrical Tanks
4) Design Aspects of Rectangular Tanks
5) Wind and Earthquake effects
6) Staging Design
1) Classification of Types of Towers
2) Loads and Load Combinations
3) Wind Effects on Towers
4) Methods of Analysis
5) Design Approaches
6) Economy and Optimisation
[Image: 02979625764970297903.jpg]
[Image: 64709196298181355238.jpg][Image: 30372680549774769487.jpg][Image: 81375386510889250135.jpg][Image: 51211181008317887944.jpg]
[-] The following 62 users Like rezart's post:62 users Like rezart's post
  • brass, ruaumoko, ilgar, Quantumm, jjmtz, Grunf, ralarcon, Clouseau, usman, Diquan, jferrer, Dell_Brett, jcoronellr, strengr, kowheng, zrilek, narendra, imatoric, ajmf77, orambo, u4406014, mastermind, jcbv, deadlord, cordoba123, ladjin, mrjoesan2, Ivan_1980, parthiban, gatob, mowafi3m, rendel_©, musssa, drkol39, jayborre, Petrit, ramla2002, Sumatra, hp_logger, hignacio43, Mhasan, kerenski_t, zego2000, rcubuk, pm81, Yasir, Administrator , suseeraj, andushi, killoobilloo, frogprinz, Nilupa, shawn, fer962933, jmpkumara, joker™, Rihpi, HellboyRBJ, davegabj, we_mbm, slowet, nickycruz
Points:136,043 EP
12-07-2010, 09:16 PM
Uploaded: Dec/07/2010, File Size: 10.29 MB, RAR'd PDFs'
[-] The following 35 users Like Grunf's post:35 users Like Grunf's post
  • rezart, usman, pedzaquino, Dell_Brett, jcoronellr, hmwere, Raktim, kowheng, sodapas, Trishu999, zrilek, vardan, wahyoe, simanta, gacella, blaze, jcbv, deadlord, cordoba123, mowafi3m, rendel_©, ravisbassi, ramla2002, Sumatra, Mhasan, zego2000, cristi, durden, lasalleguy, Nilupa, knrsa, almadar12, Umer.Aleem, fer962933, mjayanath
Points:178,871 EP
02-16-2011, 01:11 PM
Design of Steel Structures (Web Course)
Author: Prof. S. R. Satish Kumar | Size: 5.46 MB | Format: PDF | Year: 2009 | pages: 553
[Image: 67301054829429656411.jpg]
V. COMPRESSION MEMBERS
1) Buckling Strength of Ideal Columns.
2) Strength of Practical Compression Members.
3) Column Strength Curves.
4) Design of Axially Loaded Columns.
5) Design of Angles Loaded through one-leg.
6) Laced and Battenned Columns.
VI BEAMS
1) Behavior of Steel beams
2) Limit State Design of Steel Beams
3) Web Buckling and Crippling
4) Lateral Torsion Buckling Behavior of Unrestrained Beams
5) Design approach for Unrestrained Beams
6) Unsymmetrical sections and Bi-axial bending
7) Built-up Sections
8) Shear Behavior of Transversely Stiffened Plate Girder Webs
9) Provision of Moment and Shear Capacity for Plate Girders
10) Design of Stiffeners
VII BEAM-COLUMNS
1) Short Beam- Columns
2) Stability Consideration for Long Beam-Columns
3) Interaction Formula
4) Design approach to Beam- Columns
VIII COLUMN BASES
1) Introduction to Bases and Footings
2) Design of Solid Slab Base
3) Design of Gusted Base
4) Other Types of Footings
STEEL STRUCTURES II
4) Roof Systems
3) Loading
7) Dual Systems
IV. BRIDGES
V. TANKS
VI. TOWERS
6) Staging Design
This material can be moved to "Steel books" section according to opinion of the moderators.
[-] The following 37 users Like ir_71's post:37 users Like ir_71's post
  • Grunf, rezart, rendel_©, melkat, blaze, kowheng, engiman27, miquan, pm81, cowboy, Diquan, Quantumm, iam_td, usman, julioreptil, arunsmt, parwez007, seriousboy, jcbv, Ivan_1980, gatob, cesar3226, Dell_Brett, sujups, carolinandra, Clouseau, narendra, iigeniusii, monter, robertsas, lednar_ved, Hengki, sssmou, Jackass, Nilupa, oanm2000, amindoxiti
Pages (2): 1 2 Next »
  Steel Structures Design; For Lateral and Vertical Forces carolinandra 3 3,388 01-07-2022, 02:44 AM
Last Post: Veggeta
  Ductile Design of Steel Structures 2nd lamkin 8 6,131 09-06-2021, 04:15 AM
  Ultimate Limit State Design of Steel-Plated Structures apocalipse 2 2,364 11-19-2020, 03:16 PM
Last Post: Kurucz
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,284 05-14-2020, 09:19 AM
Last Post: agelos100
  Advanced Steel Design of Structures carolinandra 1 1,839 01-08-2020, 08:58 AM
Last Post: kirankumarklk
  Design of Joints in Steel and Composite Structures amindoxiti 3 2,872 12-17-2019, 06:53 AM
  Fatigue Design of Steel and Composite Structures: Eurocode 3: Design of Steel Structu asim99 3 2,989 04-30-2019, 01:29 PM
Last Post: carolinandra
