Civil Engineering Association eBooks Structural Books Steel Design of Joints in Steel and Composite Structures
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2616
Points:35,180 EP
03-28-2017, 09:21 PM
Author(s)/Editor(s): Jean-Pierre Jaspart, Klaus Weynand | Size: 11 MB | Format: PDF | Quality: Original preprint | Publisher: ECCS | Year: 2016 | pages: 401 | ISBN: 9783433029855
[Image: 73231444260346998953.jpg]
This book details the basic concepts and the design rules included in Eurocode 3
Design of steel structures: Part 1-8
Design of joints
Joints in composite construction are also addressed through references to Eurocode 4
Design of composite steel and concrete structures
Part 1-1: General rules and rules for buildings.
Attention has to be duly paid to the joints when designing a steel or composite structure, in terms of the global safety of the construction, and also in terms of the overall cost, including fabrication, transportation and erection. Therefore, in this book, the design of the joints themselves is widely detailed, and aspects of selection of joint configuration and integration of the joints into the analysis and the design process of the whole construction are also fully covered.
Connections using mechanical fasteners, welded connections, simple joints, moment-resisting joints and lattice girder joints are considered. Various joint configurations are treated, including beam-to-column, beam-to-beam, column bases, and beam and column splice configurations, under different loading situations (axial forces, shear forces, bending moments and their combinations).
The book also briefly summarises the available knowledge relating to the application of the Eurocode rules to joints under fire, fatigue, earthquake, etc., and also to joints in a structure subjected to exceptional loadings, where the risk of progressive collapse has to be mitigated.
Finally, there are some worked examples, plus references to already published examples and to design tools, which will provide practical help to practitioners.
[-] The following 51 users Like amindoxiti's post:51 users Like amindoxiti's post
  • agelos100, Dell_Brett, tomtumx, cheosmith, gulilero, simanta, civilphongvan, mgdario, milova, lasalleguy, psk62, pontiac, malc, pezhmankhan, Andrew seah, cace-01, hodzicemir, dizz, vvvv, avge, avscorreia, struceng, gianniorlati, monter, lamkin, subin91, lisine, caifan, Ivan_1980, ting tsai huang, faros3000, dinu69in, zrilek, Trishu999, cristi, carolinandra, jmksq, ruaumoko, Batman07, ssobhan, febo927, shaker, blaze, PinkPant, sodapas, K.Lee, thebeatles, harsono, kowheng, tuanpecc1, Vladimir
Likes: 12,064 in 1,232 posts
Points:63,655 EP
03-29-2017, 04:03 AM
[-] The following 16 users Like pezhmankhan's post:16 users Like pezhmankhan's post
  • cace-01, hodzicemir, dizz, vvvv, temp1366, jcbv, Dell_Brett, Aviator, oanm2000, amindoxiti, lisine, Hengki, zrilek, simanta, Batman07, sodapas
 rami1976
User ID: 34597
Threads: 339
Likes: 9,516 in 1,136 posts
Given Likes: 1379
Points:65,201 EP
06-16-2017, 06:30 AM
[-] The following 23 users Like rami1976's post:23 users Like rami1976's post
  • Batman07, Dell_Brett, tsujeevan, temp1366, ssobhan, oanm2000, amindoxiti, slowet, Nita1391, RajaK, jcbv, rezart, malc, Aviator, DamirDz, K.Lee, thebeatles, sodapas, rendel_©, febo927, simanta, kowheng, Vladimir
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
Points:29,008 EP
12-17-2019, 06:53 AM
new links
[-] The following 10 users Like andersen3's post:10 users Like andersen3's post
  • tuanpecc1, Nita1391, cace-01, rami1976, Dell_Brett, jcbv, PinkPant, oanm2000, CAMSECT, Vladimir
  Modelling Steel and Composite Structures TAFATNEB 0 2,494 04-25-2023, 10:57 AM
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 2,453 01-10-2023, 12:16 AM
Last Post: carolinandra
  Steel Structures Design; For Lateral and Vertical Forces carolinandra 3 3,384 01-07-2022, 02:44 AM
Last Post: Veggeta
  Ductile Design of Steel Structures 2nd lamkin 8 6,113 09-06-2021, 04:15 AM
  Ultimate Limit State Design of Steel-Plated Structures apocalipse 2 2,357 11-19-2020, 03:16 PM
Last Post: Kurucz
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,277 05-14-2020, 09:19 AM
Last Post: agelos100
  Australia Steel Ins Design example for multistorey composite steel framed building leong8929 2 2,774 01-18-2020, 05:45 PM
Last Post: monter
