Autodesk REVIT 2018
Autodesk REVIT 2018
[Image: 08032637657648328191.jpg]
[Image: 25201997287023940340.jpg]
[Image: 06854836419600024071.jpg]
[Image: 50543165362292216802.jpg]
Autodesk Revit is building information modeling software for architects, structural engineers, MEP engineers, designers and contractors developed by Autodesk. It allows users to design a building and structure and its components in 3D, annotate the model with 2D drafting elements, and access building information from the building model's database. Revit is 4D BIM capable with tools to plan and track various stages in the building's lifecycle, from concept to construction and later demolition.
[Image: citysign.jpg]
Revit Extentions for Revit 2018
Autodesk Model Checker for Revit 2018
Autodesk Classification Manager for Revit 2018
Autodesk Insight 360 Plug-in for Revit 2018
[-] The following 14 users say Thank You to rami1976 for this post:
  • cheosmith, Dell_Brett, cace-01, dizz, albani, oanm2000, zrilek, Aviator, deltalead, SCREAM7890, monter, TurboXUser, smrutigandh.42, bigone
Autodesk Revit 2018 x64 (multi language )+ Extensions
The source material for creating the assembly is the original ESD distribution.
Added the ability to install ALL libraries without connecting to the Internet.
Added the ability to install Revit Extensions for Autodesk Revit 2018.
Technical improvements have been made that relieve the end user of a number of problems when installing the program.
The distribution is converted to an optimized ISO image.
Added instructions for installation and activation.
  • zrilek, oanm2000, Dell_Brett, paulocs, bigone
Autodesk Revit 2018.0.1 Hot Fix (Apr 27, 2017)
Readme:
[-] The following 12 users say Thank You to rami1976 for this post:
  • zrilek, cace-01, Songoku, Dell_Brett, oanm2000, malc, oyabun, engiman27, smrutigandh.42, ali akbar, bigone, rendel_©
Autodesk Revit 2018.0.2 Hot Fix (June 7, 2017)
  • Size: 122.34 MB
Readme
[-] The following 8 users say Thank You to rami1976 for this post:
  • zrilek, oanm2000, Dell_Brett, PinkPant, smrutigandh.42, ali akbar, bigone, rendel_©
Revit 2018.1.1
Readme
What is fixed
[-] The following 9 users say Thank You to rami1976 for this post:
  • amindoxiti, joker™, cace-01, oanm2000, rendel_©, zrilek, Dell_Brett, DamaD, rezart
AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 3,993 04-21-2018, 10:51 PM
Last Post: joker™
AutoDesk InfraWorks 360 Pro 2018 BennyP 1 1,817 03-10-2018, 12:15 PM
Autodesk Inventor 2018 BennyP 5 2,863 01-26-2018, 02:13 PM
Autodesk AutoCAD Plant 3D 2018 BennyP 1 2,020 12-18-2017, 10:32 PM
Autodesk Vehicle Tracking 2018 BennyP 2 2,385 12-18-2017, 10:27 PM
