Autodesk AutoCAD 2018 (x86/x64)
Size: 1.68 GB / 2.28 GB
[Image: 89516592855973870069.jpg]
[Image: 89338673074425786205.jpg]
[Image: 25582024762550496341.jpg]
Quick Summary of AutoCAD 2018:
- Xrefs now default to relative path attachment and there are a few associated tweaks including find/replace path
- You can select objects off-screen (handier than it sounds)
- You can select objects with linetypes even when selecting the gaps
- File dialogs remember settings
- A couple more dialogs can be resized
- There are a couple more tiny user interface tweaks
- The stuff from 2017.1 is included, of course
- iDrop support is gone
[-] The following 27 users say Thank You to BennyP for this post:
  • rami1976, camto2, slowet, RajaK, 3fan, zrilek, cace-01, oanm2000, milvio, Dell_Brett, temp1366, blaze, joker™, herea, Veggeta, hatkam, yutt, caifan, BLESSED DOVE, bao2004, golpesar, bigone, stldtlr, kristoffer_89, bullfrog, Rami11, anorona
Trial Link from autodesk for 32bit version:
size = 1.67GB
[-] The following 14 users say Thank You to rami1976 for this post:
  • camto2, RajaK, 3fan, cace-01, oanm2000, milvio, Dell_Brett, temp1366, herea, mowafi3m, Rodmo376, bigone, bullfrog, dak4482
AutoDesk AutoCAD 2018 (X32-X64) Language Packs (English )
  • Size: 64 MB( 32 bit) , 104MB (64 bit)
This post has been made by CivilEA Post-Generator V2.3.1[/align]
AutoDesk AutoCAD 2018 offline Help
  • Size: 176 MB
[-] The following 11 users say Thank You to rami1976 for this post:
  • joker™, Dell_Brett, cace-01, slowet, zrilek, oanm2000, mowafi3m, caifan, oyabun, bigone, bullfrog
Here it torrent link  for AutoDesk AutoCAD 2018 (X32-X64)
[-] The following 11 users say Thank You to thanzawtun for this post:
  • oanm2000, BLESSED DOVE, Dell_Brett, mowafi3m, joker™, bigone, rodsyuk, bullfrog, rendel_©, Rami11, anorona
Patch for Autocad 2018. Not clear why Autodesk make a patch and why is not found in it's site but if the first one is O.49.0.0 Autocad 2018
the patched is O.61.0.0 Autocad 2018.0.1
[Image: 60607129538222820320.jpg]
For 64 bit was a r1 too but i don't know why.
- Uninstall version 2018.0.1 r1 (X64) first, if you have already installed it
[-] The following 13 users say Thank You to BennyP for this post:
  • RajaK, mgdario, Wijono, temp1366, cace-01, zrilek, Dell_Brett, oanm2000, mowafi3m, joker™, golpesar, bigone, bullfrog
Autocad 2018.02 update
Readme
  • zrilek, amindoxiti, Dell_Brett, hmwere, cace-01, oanm2000, golpesar, wisamnn, oyabun, bigone, taifur, caifan, Andrew seah, bullfrog
Autodesk AutoCAD 2018 (x64)_Trail
[-] The following 7 users say Thank You to kirankumarklk for this post:
  • PinkPant, RajaK, spanac, Andrew seah, stigtg, bullfrog, usman
Links existing in post #1 since 03.17 (reported bu moderator). All you need is to roll the links to see. This post is useless and the warning no. is 12. Looking at a lot of comments in your profile i can say you here in this post because the comments are blocked you are near the banning.
  • zipatton, bullfrog
AutoCAD Civil 3D 2018 BennyP 5 3,183 04-16-2018, 04:55 AM
AutoDesk InfraWorks 360 Pro 2018 BennyP 1 1,817 03-10-2018, 12:15 PM
Autodesk Inventor 2018 BennyP 5 2,862 01-26-2018, 02:13 PM
Autodesk AutoCAD Plant 3D 2018 BennyP 1 2,020 12-18-2017, 10:32 PM
Autodesk Vehicle Tracking 2018 BennyP 2 2,384 12-18-2017, 10:27 PM
